If the question is to convert a .mpy file to a disassembly -- i.e. from bytecode into text description of opcodes and arguments (e.g. load_fast "foo"), then it's not particularly complicated and doesn't use complicated encoding or variable-length patterns* (I've had to do this by hand for short sequences while debugging). I'm not aware of any pre-existing tools though, but you could probably write a tool to do this in Python. I'd love to see a radare plugin
The thing about Python though, is once you have the bytecode, converting it into something that looks like Python is not nearly as complicated as other languages. i.e. x64 assembly back to C is _very_ challenging. The main thing you lose is the names of function-local variables.
* the one exception is the way the function preamble is encoded where there's some compression, but again the scheme isn't overly complicated, and the code for it is obviously available in the VM.
