When I run the program below the new main.py is created and the old files are removed. A reset is made but the new main.py does not start to execute until after I manually press reset as well. Then the blue LED is turned on. it does not make a difference if I use pyb.reset or pyb.hard_reset.
What am I missing?
#CodeSwap.py
import os
def write_to_file(file_name, text):
with open(file_name, 'w') as source_file:
source_file.write(text)
def remove_old_code():
os.remove("CodeSwap.py")
os.remove("main.py")
class CodeSwapper(object):
def __init__(self):
pass
def write_file(self):
pass
def reset(self):
pass
#main.py
import CodeSwap as CS
green = pyb.LED(2)
green.on()
CS.remove_old_code()
CS.write_to_file("main.py", "blue = pyb.LED(4)\nblue.on()\n")
yellow = pyb.LED(3)
yellow.on()
#pyb.hard_reset()
pyb.reset()
Resetting board will not run main.py
Re: Resetting board will not run main.py
Try adding a call to pyb.sync() before the reset
If you want to see the yellow led turn on, add a delay before the reset. The way it's coded now the yellow led will only be on for about a microsecond before it gets turned off by doing the reset.
You can also try using pyb.main("file.py") in boot.py to set the script to run after boot.py finishes.
I had to change your pyb.reset() to pyb.hard_reset() (in the latest firmware its still called hard_reset). You can determine this from the repl:
I also added an import pyb to the top of your CodeSwap.py file and also added an import pyb to your generated main.py file.
To find these "issues", I copied CodeSwap.py and called main.py code_swap.py, and then from the repl I used:
import code_swap
and that showed me various errors with the script. I also tried taking your generated main.py and importing it.
With the changes mentioned above, it seems to be working properly (I also added a delay after turning on the yellow led so I could see it turn on).
Micro Python v1.4.3-154-g1082234-dirty on 2015-06-15; PYBv1.0 with STM32F405RG
>>> pyb.reset
AttributeError: 'module' object has no attribute 'reset'
>>> pyb.hard_reset
<function>
import code_swap
Hmm, I don't have pyb.reset or pyb.hard_reset.
pyb.info() or help() do not show the micropython version, how can I see that?
Weren't they included from the start?
If you press Contol-D you should see the python version.
I don't believe that pyb.reset and pyb.hard_reset were included in the Kickstarter boards.
The current (latest) version fo the firmware is:
Micro Python v1.4.4-16-ga06c38b-dirty on 2015-06-21; PYBv1.0 with STM32F405RG
Micro Python v1.3.3 on 2014-10-02; PYBv1.0 with STM32F405RG
Bought it after kickstarter but maybe it was the same batch, will try to update the board.
Works now, had to upgrade the board.
