Here is the MQTT client code that will run on the ESP32.
from time import sleep
from dht import DHT22
SERVER = '192.168.1.22' # MQTT Server Address (Change to the IP address of your Pi)
CLIENT_ID = 'ESP32_DHT22_Sensor'
TOPIC = b'temp_humidity'
client = MQTTClient(CLIENT_ID, SERVER)
client.connect() # Connect to MQTT broker
sensor = DHT22(Pin(15, Pin.IN, Pin.PULL_UP)) # DHT-22 on GPIO 15 (input with internal pull-up resistor)
sensor.measure() # Poll sensor
t = sensor.temperature()
h = sensor.humidity()
if isinstance(t, float) and isinstance(h, float): # Confirm sensor results are numeric
msg = (b'{0:3.1f},{1:3.1f}'.format(t, h))
client.publish(TOPIC, msg) # Publish sensor data to MQTT topic
print(msg)
print('Invalid sensor readings.')
except OSError:
print('Failed to read sensor.')
sleep(4)
Here is the Raspberry Pi Python MQTT client code.
import paho.mqtt.client as mqtt
import Adafruit_SSD1306
from PIL import Image, ImageDraw, ImageFont
disp = Adafruit_SSD1306.SSD1306_128_32(rst=0)
disp.begin()
FONT_PATH = '/usr/share/fonts/truetype/piboto/PibotoCondensed-Regular.ttf'
FONT = ImageFont.truetype(FONT_PATH, 22)
def display_data(t, h):
image = Image.new('1', (disp.width, disp.height))
draw = ImageDraw.Draw(image)
# Draw temperature / Humidity values.
draw.text((0, 8), '{0}°C'.format(t), font=FONT, fill=255)
draw.text((71, 8), '{0}%'.format(h), font=FONT, fill=255)
# Draw bar charts.
draw.rectangle((0, 0, 50, 8), outline=255, fill=0)
draw.rectangle((71, 0, 121, 8), outline=255, fill=0)
draw.rectangle((0, 0, t / 100.0 * 50, 8), outline=255, fill=255)
draw.rectangle((71, 0, 71 + (h / 100.0 * 50), 8), outline=255, fill=255)
# Send to OLED display.
disp.clear()
disp.image(image)
disp.display()
# Callback fires when conected to MQTT broker.
def on_connect(client, userdata, flags, rc):
print('Connected with result code {0}'.format(rc))
# Subscribe (or renew if reconnect).
client.subscribe('temp_humidity')
# Callback fires when a published message is received.
def on_message(client, userdata, msg):
# Decode temperature and humidity values from binary message paylod.
t,h = [float(x) for x in msg.payload.decode("utf-8").split(',')]
print('{0}°C {1}%'.format(t, h))
display_data(t, h) # Display data on OLED display.
client = mqtt.Client()
client.on_connect = on_connect # Specify on_connect callback
client.on_message = on_message # Specify on_message callback
client.connect('localhost', 1883, 60) # Connect to MQTT broker (also running on Pi).
# Processes MQTT network traffic, callbacks and reconnections. (Blocking)
client.loop_forever()
