Help interfacing with C function and input parameters format
Keja
Re: Help interfacing with C function and input parameters format
Post by Keja » Fri Apr 23, 2021 4:09 pm
thanks,
it helps a lot.
With your suggestion when I compile I now get :
GEN build/modrun.config.h
CC modrun.c
LINK build/modrun.o
LinkError: build/modrun.o: undefined symbol: mp_obj_get_array
make: *** [build/modrun.native.mpy] Error 1
my makefile :
MPY_DIR = ../../..
# Name of module
MOD = modrun
# Source files (.c or .py)
SRC = modrun.c
# Architecture to build for (x86, x64, armv7m, xtensa, xtensawin)
ARCH = armv7emsp
#ARCH = x64
# Include to get the rules for compiling and linking the module
include $(MPY_DIR)/py/dynruntime.mk
Thanks for the support
stijn
Post by stijn » Fri Apr 23, 2021 6:24 pm
dynruntime.h doesn't have mp_obj_get_array so that won't work. Compile a C module instead? Or cast the input argument to an mp_type_list* and access len/items directly (best after checking mp_obj_is_type); don't have experience with the dynamic runtime so not sure if that is the correct way.
Keja
Post by Keja » Fri Apr 23, 2021 7:24 pm
I ended up compiling a C module instead and it works :)
thank you , your help is much appreciated
Keja
Post by Keja » Sat Apr 24, 2021 8:14 am
just for information PR#7154 adds mp_obj_get_array to the dynamic runtime and it now also compiles fine with it.
thanks again for helping
