UDP boardcast can Not be received
lgyer
Post by lgyer » Wed Jun 16, 2021 1:05 pm
Hi guys
Does micropython support UDP boardcast mode?
When I try to use udp boardcast to transfer some messages, but my server can't receive any message. But if I use unicast mode, it can work.
The code as following:
Server running in my hardware by using micropython
import socket
def do_connect():
    if not sta_if.isconnected():
        sta_if.active(True)
        sta_if.connect('Leo', '1234567890')
            time.sleep_ms(500)
    print('network config:', sta_if.ifconfig())
    return sta_if.ifconfig()[0]
local_ip = do_connect()
server = socket.socket(socket.AF_INET, socket.SOCK_DGRAM) # UDP protocol
server.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
server.bind((local_ip, 61234))
print("start Listening at 61234")
    data, client_addr = server.recvfrom(1000)
    print('client connected from', client_addr)
    print("data: ", data)
Client running in my PC by using python language
import socket
import sys
sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
sock.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
sock.setsockopt(socket.SOL_SOCKET, socket.SO_BROADCAST, 1)
network = '<broadcast>'
#network = '172.20.10.12'
port = 61234
sock.sendto('Client broadcast message!'.encode('utf-8'), (network, 61234))
lgyer
Re: UDP boardcast can Not be received
Post by lgyer » Fri Jun 18, 2021 5:34 am
Can anyone give any hints?
fe2o3
Post by fe2o3 » Fri Jun 18, 2021 7:01 pm
I thought I had posted this but...
For receiving broadcasts, change your variable 'local_ip' in the client to
either '0.0.0.0', which will permit broadcasts to be received on any IP address of the host or
set it to the broadcast address for the network the broadcast is sent.
For example, if your host is 192.168.1.25 then that network's broadcast
address is usually 192.168.1.255. The all-zeros address may be the easiest.
-Rusty-
gleria
Post by gleria » Sat Jun 19, 2021 3:58 pm
Thanks for the interesting solution. I just have the same case. Agile software development companies https://mlsdev.com/services/custom-software-development usually employ both teams of programmers and developers. The developers create software applications by using software development tools and methods. Then, teams of testers test the applications to ensure that they work and are correct. Software tester jobs require a fair amount of programming skill, but they do not require a great deal of prior knowledge of software development in general. Usually, a software tester will be hired as a temporary employee and then need to be trained in order to take the job full-time.
lgyer
Post by lgyer » Mon Jun 21, 2021 2:47 am
-Rusty-
I have tried to change 'local_ip' to '0.0.0.0', but the result is same as before.
My lab environment as following:
1. There is a wifi hotspot created in my PC.
2. My esp32 is connected with this wifi hotspot.
3. Then I run my code to test UDP boardcast.
Am I right in these steps?
ESP32 code:
import socket
def do_connect():
        sta_if.active(True)
        sta_if.connect('myy', '1234567890')
            time.sleep_ms(500)
local_ip = '0.0.0.0'
PC python code
import socket
import sys
port = 61234
lgyer
Post by lgyer » Mon Jun 21, 2021 2:49 am
Hi gleria
Did your hardware receive the UDP boardcast in this way? Could you please share your code?
fe2o3
Post by fe2o3 » Mon Jun 21, 2021 6:04 am
Both code segments work for me although my PC is running Linux.
(Still not understanding the '<broadcast>' string)
Your hotspot may not be passing UDP broadcasts.
lgyer
Post by lgyer » Mon Jun 21, 2021 10:26 am
Ah,it's a good news to me. I'll try to use another wifi.
gleria
Post by gleria » Mon Jun 21, 2021 10:48 am
I solved this problem. Thanks one more time.
