Add frozen code to the machine module?
MasterOfGizmo
Post by MasterOfGizmo » Fri Jan 28, 2022 10:31 am
There are discussions about machine.Encoder and machine.Counter classes in github. These are implemented in C. I would like to give a python variant a trial and would like to add it as a frozen class to the machine module so my versions are compatible with the ones from the existing PR's.
Is that possible at all? Can one mix python and C in the same module? If yes, how? Simply adding machine/Encoder.py to port/esp32/modules does not work.
pidou46
Re: Add frozen code to the machine module?
Post by pidou46 » Tue Feb 01, 2022 7:12 am
If I understand your need accordingly, I think Damien is cooking something up:
https://github.com/micropython/micropython/pull/8191
nodemcu V2 (amica)
MasterOfGizmo
Post by MasterOfGizmo » Tue Feb 01, 2022 11:57 am
Thanks for the response. But ... no, I don't think this is what I am searching for. I don't have a problem including my code into the firmware. This already works.
I can add
port/esp32/modules/mymachine/Encoder.py
This will be converted into MPY and included into the firmware. This can then be used like
from mymachine import Encoder
But the documentation of the Counter and Encoder classes requires them to be part of the machine module. So I'd like to add
port/esp32/modules/machine/Encoder.py
That also compiles successfully. But
from machine import Encoder
won't work. Probably because I cannot simply add something to the internal machine module. The question is: How do I add python code to a built-in native module? Is this possible at all?
