random.sample or similar?
Hi all.
New to MicroPython and a newbie programmer.
I'm trying to build a gallery target for my air gun shooting, using the Pi Pico to control various servos, and LCD screen with rotary encoder for some sort of menu system. I was hoping to get the targets popping up in random sequence. The targets are controlled by individual servos (10 probably), and they should only pop up once per cycle.
I looked into using "randint", but although that would give me random intergers which I can work with, it can give me repeats. Searching the Python sites, it looks like "random.sample" might work. However that is not an option for MicroPython.
Any other suggestions? Or should I switch to another language that might support what I need from it?
Thanks in advance.
Adrian
Thanks in advance.
Adrian
- OlivierLenoir
Re: random.sample or similar?
You can use random.choice().
Output is:
from random import choice
targets = ['Target1', 'Target2', 'Target3', 'Target4']
for t in range(10):
target = choice(targets)
print(f'{t} - {target}')
0 - Target4
1 - Target1
2 - Target1
3 - Target3
4 - Target3
5 - Target4
6 - Target1
7 - Target4
8 - Target2
9 - Target3
Olivier Lenoir
https://gitlab.com/olivierlenoir
- OlivierLenoir
As you just want to pop a target once. You do this:
You get this:
targets = ['Target1', 'Target2', 'Target3', 'Target4', 'Target5', 'Target6', 'Target7', 'Target8', 'Target9', 'Target10']
count_target = range(len(targets))
for t in count_target:
targets.remove(target)
0 - Target4
1 - Target8
2 - Target10
3 - Target9
4 - Target2
5 - Target5
6 - Target1
7 - Target3
8 - Target7
9 - Target6
Olivier Lenoir
Thanks for that Olivier. This was exactly how I thought the workaround would be. Removing the "choice" after it has been "chosen" after each round. You saved me a few days trying to google how to do it!OlivierLenoir wrote: ↑Sun Jul 03, 2022 6:33 amAs you just want to pop a target once. You do this:Code: Select all
from random import choice targets = ['Target1', 'Target2', 'Target3', 'Target4', 'Target5', 'Target6', 'Target7', 'Target8', 'Target9', 'Target10'] count_target = range(len(targets)) for t in count_target: target = choice(targets) targets.remove(target) print(f'{t} - {target}')
For my learning what this the "f" in this line?
- OlivierLenoir
print('{t} - {target}'.format(t=t, target=target))
Olivier Lenoir
Just to make it easier to search for more information, technically it's a "formatted string literal" (which other languages call "string interpolation"). "string formatting" generally refers to all the different ways of making a formatted string (including the % operator and str.format).
https://docs.python.org/3/tutorial/inpu ... -f-strings
- OlivierLenoir
Another solution is to mimic the shuffle function.
Same solution without target variable.
from random import randrange
count_target = len(targets)
for _ in range(count_target):
target = targets.pop(randrange(0, count_target - 1))
targets.append(target)
print(targets)
targets.append(targets.pop(randrange(0, count_target - 1)))
print(targets)
Olivier Lenoir
