serial data reading with pico
scruss
Re: serial data reading with pico
Post by scruss » Wed Jul 20, 2022 3:20 pm
filip12241224 wrote:
Tue Jul 19, 2022 5:07 pm
I have a device with rs232 output
What do you know about the device? Does it have a manual or datasheet?
If you don't know what baud rate (bit rate) and how characters are sent (7/8 bits, 1/2 start bits, 1/2 stop bits, No/Even/Odd/Mark/Space parity bit, you're probably going to have to spend some tedious time with a logic analyzer working out the protocol
karfas
Post by karfas » Wed Jul 20, 2022 8:14 pm
Wed Jul 20, 2022 10:24 am
today even the old code returns "none" so i think the connection may be bad
Maybe you should check first if your signal really reaches the UART ?
I usually have a few LEDs soldered to a 100 Ohm resistor in my toolbox. They are a very simple, very low-cost way to detect whether some signal arrives at a specific point in your circuit.
This works well with relatively low transfer speeds (19k2) for RS232, RS485, UART, whatever. You can correlate your actions (e.g. typing in putty) with the short flashes of the LED...
A few hours of debugging might save you from minutes of reading the documentation! :D
filip12241224
Post by filip12241224 » Fri Jul 22, 2022 2:16 pm
Post by Roberthh » Fri Jul 22, 2022 2:28 pm
What's puzzling me is that the loopback test does not work. That is the minimal test case. Until that one does works, is make no sense to connected external data sources.
Post by Roberthh » Fri Jul 22, 2022 2:40 pm
So the wiring for loopback should be as in the sketch below:
TheSilverBullet
Post by TheSilverBullet » Fri Jul 22, 2022 3:03 pm
Once the hardware stuff is sorted out, maybe this one will be helpful: 8-)
baudratelist = [300*2**i for i in range(8)]
baudratelist.extend([57600*2**i for i in range(2)])
bitlist =[7,8,9]
paritylist = [None,0,1]
stoplist = [1,2]
print(baudratelist)
print(bitlist)
print(paritylist)
print(stoplist)
for baudrate in baudratelist:
    for bits in bitlist:
        for parity in paritylist:
            for stop in stoplist:
                    u = None
                    u = machine.UART(0, baudrate)
                    u.init(baudrate=baudrate, bits=bits, parity=parity, stop=stop)
                    print(baudrate,bits,parity,stop)
                    for t_ms in range(1000):
                        if u.any():
                            value = u.read(1)
                            if type(value) is bytes:
                                value = ord(value)
                                c = chr(value) if 32 <= value <= 127 else '.'
                                print(f'  {c}  Bin:{value:08b}   Dec:{value:3d}   Hex:{value:02x}')
                            time.sleep_ms(1)
                except Exception as e:
                    print(e)
                    if u:
                        u.deinit()
filip12241224
Post by filip12241224 » Fri Jul 22, 2022 3:35 pm
Post by Roberthh » Fri Jul 22, 2022 3:56 pm
Good. Now you know it works up to the RS232 side. Next: what is connected to the RS232 side?
filip12241224
Post by filip12241224 » Fri Jul 22, 2022 5:02 pm
Post by Roberthh » Fri Jul 22, 2022 6:44 pm
Is the device connected with the RJ11 or the DB9 connector?
Did you check the silent voltage levels at the RS232 side? These should be -5 to -12 V.
Does the device need control signals at a specific level? Like RTS and DTR?
