Working WS2812 LED Example
Markus Gritsch
Post by Markus Gritsch » Fri Jun 06, 2014 10:34 am
here is some MicroPython code which drives a WS2812 LED:
# MicroPython example for controlling one WS2812 LED.
# Method similar to http://www.espruino.com/WS2811
from pyb import SPI
spi = SPI(1, SPI.MASTER, baudrate=6400000, polarity=0, phase=1)
spi.send(chr(0x00))
def byte2bits(byte):
    b0 = chr(0x03)
    b1 = chr(0x0F)
    bits = ''
    mask = 0x80
    while mask != 0:
        bits += b0 if ( byte & mask ) == 0 else b1
        mask >>= 1
    return bits
def sendColor(red, green, blue):
    spi.send(byte2bits(green)+byte2bits(red)+byte2bits(blue))
import math
n = 0
    r = int((1 + math.sin(n * 0.1324)) * 127)
    g = int((1 + math.sin(n * 0.1654)) * 127)
    b = int((1 + math.sin(n * 0.1)) * 127)
    sendColor(r, g, b)
    n += 1
    pyb.delay(20)
Have fun,
Markus
pfalcon
Re: Working WS2812 LED Example
Post by pfalcon » Sun Jun 08, 2014 1:56 pm
Markus Gritsch, great work and report on results! It only misses a video (heck, it's about changing colors, I wanna see that!) to deserve an entry in "Projects" forum. Well, just kidding - surely, it deserves to be there already, and please kindly consider postinf future posts like this there - that's where new users will look for expiration and ideas, and we don't want them to think there's lack of cool things to do with MicroPython, right? Thanks!
Awesome MicroPython list
fma
Post by fma » Fri Jun 13, 2014 8:19 am
Hi Markus!
Thanks for sharing your code. I'm using it to drive a 11x11 leds matrix. For now, I only soldered 11 leds, and you code works fine (I didn't see the issue you reported here, except when the SD card is enumarated/mounted, which is not really surprising).
Just to say that I'm very interested in any progress you can make on this project ;)
Frédéric
Markus Gritsch
Post by Markus Gritsch » Fri Jun 13, 2014 10:58 am
The PCBs finally arrived and driving 10 LEDs works with an acceptable frame-rate: http://youtu.be/GHmoE9ui4NU
Driving over hundred LEDs might be difficult with my approach, since it will get quite slow, and I am not sure if there is enough memory to hold the data string without any optimization.
Here is the updated code:
from pyb import SPI
spi.send(chr(0x00))
    b0 = chr(0x03)
    b1 = chr(0x0F)
    bits = ''
    mask = 0x80
    while mask != 0:
        mask >>= 1
    return bits
import math
import gc
buf = bytearray(10 * 3)
n = 0
    pos = 0
    while pos < len( buf ):
        red = int((1 + math.sin((n + pos) * 0.1324)) * 127)
        green = int((1 + math.sin((n + pos) * 0.1654)) * 127)
        blue = int((1 + math.sin((n + pos) * 0.1)) * 127)
        buf[pos] = green; buf[pos + 1] = red; buf[pos + 2] = blue
        pos += 3
    data = ''.join(list(map(byte2bits, buf)))
    pyb.disable_irq()
    spi.send(data)
    pyb.enable_irq()
    gc.collect()
    print(n)
    n += 1
fma
Post by fma » Fri Jun 13, 2014 11:12 am
Nice!
I tried to activate 121 leds, and I get a out of memory error :mrgreen:
I also tried to use code emitters on byte2bits() function, but none of them work; I don't remember the errors. What can cause a problem, here?
Frédéric
Markus Gritsch
Post by Markus Gritsch » Sat Jun 14, 2014 8:01 pm
fma wrote:What can cause a problem, here?
Follow the directions pfalcon gave here: http://forum.micropython.org/viewtopic. ... p=621#p621
randomhuman
Post by randomhuman » Sun Jun 15, 2014 1:18 pm
Nice one, works well with Adafruit "Neopixels" as well, they use that same LED.
randomhuman
Post by randomhuman » Sun Jun 15, 2014 4:14 pm
It is possible to run the SPI bus at half the baud rate, as the Espruino example was doing. This requires only four bits to be sent per actual bit of color data, which should help with the memory requirements. This might not be the best way to do it, but what I have looks like this:
from pyb import SPI
spi = SPI(2, SPI.MASTER, baudrate=3200000, polarity=0, phase=1)
spi.send(chr(0x00))
def convert_byte_4(byte, zero_bits, one_bits):
    bits = bytearray(4)
    mask = 0x80
    for bit in range(0, 8, 2):
        bit1 = (zero_bits if (byte & (mask >> bit) == 0) else one_bits)
        bit2 = (zero_bits if (byte & (mask >> (bit + 1)) == 0) else one_bits)
        bits[bit//2] = bit1 << 4 | bit2
    return bits
def send_color(red, green, blue):
    ba = bytearray()
    for byte in (green, red, blue):
        converted = convert_byte_4(byte, 0x01, 0x3)
        for b in converted:
            ba.append(b)
    spi.send(ba)
Markus Gritsch
Post by Markus Gritsch » Mon Jul 07, 2014 2:47 pm
Just for completeness, here is the code without the big string concatenation. However, it still runs 2.5 times faster with the explicit call to gc.collect() in place.
from pyb import SPI
spi.send(chr(0x00))
import math
import gc
led_count = 10
buf = bytearray(led_count * 3)
spi_data = bytearray(len(buf) * 8)
def buf2data():
    b0 = 0x03
    b1 = 0x0F
    i = 0
    size = len(spi_data)
    while i < size:
        byte = buf[ i >> 3 ]
        mask = 0x80
        while mask != 0:
            spi_data[ i ] = b0 if ( byte & mask ) == 0 else b1
            mask >>= 1
            i += 1
def send_buf():
    buf2data()
    pyb.disable_irq()
    spi.send(spi_data)
    pyb.enable_irq()
    gc.collect()
n = 0
def step():
    global n
    pos = 0
        shift = 0
        red = int((1 + math.sin((n + pos) * 0.1324)) * 127) >> shift
        green = int((1 + math.sin((n + pos) * 0.1654)) * 127) >> shift
        blue = int((1 + math.sin((n + pos) * 0.1)) * 127) >> shift
        pos += 3
    send_buf()
    print(n)
    n += 1
def loop():
        step()
        pyb.delay(10)
loop()
kfricke
Post by kfricke » Mon Jul 07, 2014 10:25 pm
Slight modification makes a rudimentary clock on a led ring. The time is off by a bunch of units, but works like a charm. I do use one of those 12x LED rings.
from pyb import SPI
spi.send(chr(0x00))
import math
import gc
led_count = 12
def buf2data():
    b0 = 0x03
    b1 = 0x0F
    i = 0
    while i < size:
        mask = 0x80
        while mask != 0:
            mask >>= 1
            i += 1
def send_buf():
    buf2data()
    pyb.disable_irq()
    spi.send(spi_data)
    pyb.enable_irq()
    gc.collect()
rtc = pyb.RTC()
def step():
    global rtc
    dt = rtc.datetime()
    hour = dt[4]
    minute = dt[5]
    second = dt[6]
    print(hour, minute, second)
    pos = 0
    for i in range(0, len(buf)):
        buf[i] = 0
    buf[int(hour / 2) * 3 + 1] = 8
    buf[int(minute / 5) * 3 + 2] = 8
    buf[int(second / 5) * 3] = (second % 2) * 16
    send_buf()
def loop():
        step()
        pyb.delay(500)
loop()
