How do you move files inside sdcard with micropython?
Re: How do you move files inside sdcard with micropython?
Post by Roberthh » Tue Aug 01, 2017 9:50 am
Yes.
f.readlines() would read all lines in the file and put the into a list.
so you could do it like:
    f = open('/sd/data/data5.csv')
    content = f.readlines()
    f.close()
    for data in content:
        u2.write(data.rstrip("\n"))
or even simpler:
    for data in f:
    f.close()
skemm
Post by skemm » Tue Aug 01, 2017 11:25 am
alright, solved it by implementing a few lines:
lines = f.readlines()
line = lines[iline]
u2.write(line)
if iline < len(lines):
iline = iline + 1
iline = 0
skemm
Post by skemm » Wed Aug 02, 2017 3:00 am
Roberthh wrote:Yes.
    f.close()
or even simpler:
    for data in f:
    f.close()
I tried this but I got memory allocation related errors instead
Post by Roberthh » Wed Aug 02, 2017 5:28 am
Should not. The memory allocation should be equal or in the second case less. At which line do you get the error?
anhay20171
Post by anhay20171 » Wed Jul 06, 2022 5:45 am
Roberthh wrote:
Tue Jul 25, 2017 5:31 am
You can use uos.mkdir(dir) to create a directory, like uos.mkdir("storage"), and use uos.rename() to move files, like:
uos.rename("/SD/data0", "/SD/storage/data0").
Thank you for this answer. I have another question, what if i want to move files inside sd card to "the outside", such as:
uos.rename("sd/a.png","static/a.png")
I have tried the above command but encounter:
OSError: [Errno 1] EPERM
Post by jimmo » Wed Jul 06, 2022 6:38 am
This doesn't work in regular Python either when moving across filesystems. You'd normally use functions from the shutil for working with files like this.
There's an implementation of shutil.copyfileobj in micropython-lib
https://github.com/micropython/micropyt ... /shutil.py
You could implement shutil.move as something like the following (untested!)
def move(src, dest):
  with open(src, 'rb') as src_file:
    with open(dest, 'wb') as dest_file:
      copyfileobj(src_file, dest_file)
anhay20171
Post by anhay20171 » Thu Jul 07, 2022 11:08 am
Thank you! It worked :D
Post by Roberthh » Thu Jul 07, 2022 11:39 am
the utility upysh from micropython-lib has a cp command. upysh: https://github.com/micropython/micropyt ... thon/upysh
anhay20171
Post by anhay20171 » Fri Jul 08, 2022 7:51 am
Thank you! It worked! it's amazing when you and the one above all know solution for this issue. I wonder how have you learned to know the solution, i get no results when searching upysh in micropython doc: https://docs.micropython.org/en/latest/ ... ea=default
Post by jimmo » Fri Jul 08, 2022 1:09 pm
It's true, we need to do more to make micropython-lib more discoverable.
There's a note at the end of the first section of https://docs.micropython.org/en/latest/ ... index.html about micropython-lib.
I recommended `shutil` because that is the way to do this because that's how you do it in Python, and honestly I have never even noticed upysh before. I think originally this was designed to provide a sort of shell like interface at the MicroPython REPL. Robert knows about the cp() function because he implemented it :) (see https://github.com/micropython/micropyt ... 413a49ff4b )
I wonder if we should move the implementation of these functions over to shutil and make upysh use shutil?
