input() with uasyncio
f16falcona46
Post by f16falcona46 » Sat Mar 13, 2021 6:06 am
I have been using uasyncio to process characters from the serial console while also processing other events. However, just processing raw characters is a little inconvenient, since there's no history, no echo (by default), and no cursor handling.
My question is, is there an existing function (built-in or not) that basically acts like the builtin input() (with the cursor support, history, etc.), but is async?
Ideally something like:
async def handle_user_command():
        command = await async_input()
        #process command
If such a function doesn't exist, then is there a way I can access the readline library from within micropython and feed it individual characters?
Any information would be greatly appreciated.
CmdrDeLiver
Re: input() with uasyncio
Post by CmdrDeLiver » Sat Mar 13, 2021 7:29 pm
Peter has a wonderful tutorial for uasynio. It includes demos and I'd be surprised if one of them doesn't address your need. If you don't find a solution there, perhaps someone will have a suggestion here.
Post by pythoncoder » Sun Mar 14, 2021 2:51 pm
Thank you for your kind comment, but I'm afraid I don't know a way to meet the needs of @f16falcona46.
CmdrDeLiver
Post by CmdrDeLiver » Mon Mar 15, 2021 12:48 am
Thanks for all your hard work Peter.
f16falcona46
Post by f16falcona46 » Thu May 13, 2021 8:10 am
Thanks for the info Peter. Your tutorials are actually what got me into async programming in the first place.
