Writing to a text file on the pyboard fails ?.
alexsunny123
Post by alexsunny123 » Sun Mar 14, 2021 12:34 pm
In this example, the expectation is that I ought to be able to read back exactly what I put into the file. What I actually get back is an empty file.
It occurred to me that this might actually be an expected behavior, and that perhaps there is a manual technique that allows me to flush the file?
CODE: SELECT ALL
Micro Python v1.3.3 on 2014-10-02; PYBv1.0 with STM32F405RG
>>> import os
>>> os.listdir()
['main.py', 'pybcdc.inf', 'README.txt', 'boot.py', '.Trash-1000']
>>> open("foo.txt", "w").write("hello world")
11
>>> os.listdir()
['main.py', 'pybcdc.inf', 'README.txt', 'boot.py', 'foo.txt', '.Trash-1000']
>>> open("foo.txt").read()
The use case here, is that I want to do stuff like:
* Periodically record something to a local text file, either in pyboard memory or on the SD card.
* As part of a code deployment process, automatically generate ,py files on the pyboard which can then be executed.
thanks
alexsunny
Re: Writing to a text file on the pyboard fails ?.
Post by Roberthh » Sun Mar 14, 2021 1:01 pm
You should close the file, or use a "with ..." clause.
f = open("foo.txt", "w")
f.write("hello world")
f.close()
or:
with open("foo.txt", "w") as f:
Post by pythoncoder » Sun Mar 14, 2021 2:54 pm
The "with" context manager is preferable because the file will always be closed, even if an exception occurs.
rcolistete
Post by rcolistete » Tue Mar 16, 2021 4:25 am
Remember to sync the buffer with the file system after closing the file. For Pyboard, it is the pyb.sync() function :
pyb.sync()
