Blynk (lib-python, i.e. blynklib_mp.mpy) in combination with uasyncio
Primesty
Post by Primesty » Thu Mar 18, 2021 1:29 am
Hi all,
I'm working on a project on an ESP32 with MicroPython 1.14, in which I would like to combine blynk and other asynchronous tasks. I'm using blynklib_mp.mpy to reduce the RAM usage. My problem arises when I try to combine blynk and uasyncio.
The 'pure' blynk code (based on their examples - https://github.com/blynkkk/lib-python/b ... ual_pin.py) works great and seamlessly with the app via my local blynk server, which is running on a Raspberry Pi 3+.
import blynklib_mp as blynklib
import dht
import gc
sensor = dht.DHT22(Pin(23))
led = Pin(2, Pin.OUT)
WIFI_SSID = 'XXX'
WIFI_PASS = 'XXX'
wifi = network.WLAN(network.STA_IF)
wifi.active(True)
wifi.connect(WIFI_SSID, WIFI_PASS)
# check if board connected
connect_status = wifi.isconnected()
# initialize Blynk
blynk = blynklib.Blynk(token = "XXX", server = 'X.X.X.X, port = XX)
WRITE_EVENT_PRINT_MSG = "[WRITE_VIRTUAL_PIN_EVENT] Pin: V{} Value: '{}'"
T_COLOR = '#f5b041'
H_COLOR = '#85c1e9'
ERR_COLOR = '#444444'
T_VPIN = 3
H_VPIN = 4
# register handler for virtual pin V4 write event
@blynk.handle_event('read V{}'.format(T_VPIN))
def read_handler(vpin):
    temperature = 0
    humidity = 0
    # read sensor data
        sensor.measure()
        temperature = sensor.temperature()
        humidity = sensor.humidity()
    except OSError as o_err:
        print("Unable to get DHT22 sensor data: '{}'".format(o_err))
    # change widget values and colors according read results
    if temperature > 25 or humidity > 50:
        blynk.set_property(T_VPIN, 'color', 'red')
        blynk.set_property(H_VPIN, 'color', 'red')
        blynk.virtual_write(T_VPIN, temperature)
        blynk.virtual_write(H_VPIN, humidity)
        # show widgets aka 'disabled' that mean we had errors during read sensor operation
        blynk.set_property(T_VPIN, 'color', T_COLOR)
        blynk.set_property(H_VPIN, 'color', H_COLOR)
@blynk.handle_event('write V2')
def button_handler(pin, value):
        if value == ['1']:
                print(WRITE_EVENT_PRINT_MSG.format(pin, value))
                print('LED allumee')
                led(1)
                print('LED eteinte')
                led(0)
# infinite loop that waits for event
        blynk.run()
Again, the above works fine. However, when I try something like this:
import dht
import uasyncio
import gc
WIFI_SSID = 'XXX'
WIFI_PASS = 'XXX'
wifi.active(True)
# initialize Blynk
T_COLOR = '#f5b041'
H_COLOR = '#85c1e9'
T_VPIN = 3
H_VPIN = 4
    temperature = 0
    humidity = 0
    # read sensor data
        sensor.measure()
        if value == ['1']:
                led(1)
                led(0)
async def run_blynk():
        blynk.run()
        await uasyncio.sleep_ms(5)
async def read_temp(sensor):
        sensor.measure()
        #humidity = sensor.humidity()
        print(temperature)
        await uasyncio.sleep_ms(1000)
# Setup async app-run
def set_global_exception():
    def handle_exception(loop, context):
        import sys
        sys.print_exception(context["exception"])
        sys.exit()
    loop = uasyncio.get_event_loop()
    loop.set_exception_handler(handle_exception)
async def main():
    uasyncio.create_task(read_temp(sensor))
    await blynk.run()
    asyncio.run(main())
finally:
    asyncio.new_event_loop()
gc.collect()
gc.threshold(gc.mem_free() // 4 + gc.mem_alloc())
I get this error
  File "uasyncio/core.py", line 1, in run_until_complete
  File "main.py", line 89, in read_temp
  File "dht.py", line 17, in measure
OSError: [Errno 110] ETIMEDOUT
MicroPython v1.14 on 2021-02-02; ESP32 module with ESP32
By playing around with the 'placement' of code, i.e. have blynk_run be in the create_task function vs. the await part and with different await ms timings in the async functions I've managed to get it running a little bit like this
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:5008
ho 0 tail 12 room 4
load:0x40078000,len:10600
ho 0 tail 12 room 4
load:0x40080400,len:5684
entry 0x400806bc
        ___  __          __
       / _ )/ /_ _____  / /__
      / _  / / // / _ \/  '_/
     /____/_/\_, /_//_/_/\_\
            /___/ for Python v0.2.6
21.2
21.3
21.2
21.3
21.3
21.2
21.3
21.3
21.3
[WRITE_VIRTUAL_PIN_EVENT] Pin: V2 Value: '['1']'
LED allumee
21.3
[WRITE_VIRTUAL_PIN_EVENT] Pin: V2 Value: '['0']'
LED eteinte
21.3
Unable to get DHT22 sensor data: '[Errno 110] ETIMEDOUT'
21.3
  File "main.py", line 105, in <module>
  File "main.py", line 102, in main
  File "main.py", line 87, in read_temp
While it read the temp for a little and responded to inputs in the app, it ended in the same error ultimately.
I'm at a loss here of making these two, blynk and async work together and would be grateful for any input or suggestions you have.
Re: Blynk (lib-python, i.e. blynklib_mp.mpy) in combination with uasyncio
Post by pythoncoder » Thu Mar 18, 2021 1:16 pm
I have no knowledge of blynk but a couple of points come to mind re uasyncio. You have
async def main():
    await blynk.run()
The last line will only work if blynk.run is defined with async def.
A minor point is that the final two lines
gc.collect()
will only run after your actual application terminates or is interrupted with ctrl-c. I doubt this was your intention.
Hopefully someone who actually knows blynk will pop up with something more concrete. Crucial to understanding this is knowing which blynk calls block.
Primesty
Post by Primesty » Thu Mar 18, 2021 7:42 pm
Thanks for the answer, Peter!
Yes, I removed the `gc` stuff. You're right that didn't really matter. It looks like the run() function is not written as an async function. So I re-wrote the run() function with async in the actual blynk lib:
    async def run(self):
                if not self.connected():
                    self.connect()
                        self.read_response(timeout=self.SOCK_TIMEOUT)
                        if not self.is_server_alive():
                            self.disconnect('Server is offline')
                    except KeyboardInterrupt:
                        raise
                    except BlynkError as b_err:
                        self.log(b_err)
                        self.disconnect()
                    except Exception as g_exc:
                        self.log(g_exc)
            except:
                pass
            await uasyncio.sleep_ms(10)
And then in main.py, I'm running
async def main():
    set_global_exception()  # Debug aid
    await blynk.run()
    uasyncio.run(main())
finally:
    uasyncio.new_event_loop()
And then I also made one of the blynk handler functions asyncronous
async def read_handler(vpin):
    temperature = 0
    humidity = 0
    # read sensor data
        sensor.measure()
    await uasyncio.sleep_ms(10) #if this is there button works
        if value == ['1']:
                led(1)
                led(0)
This way, I can open the Blynk app, which connects and I can turn the led on/off via the app while the temp/hum are printed in the console reliably. However, while the button in the app works, the temp and hum are *not* synced to the app.
        ___  __          __
20.8 45.7
20.8 45.6
20.8 45.6
20.8 45.6
20.8 45.6
LED allumee
20.8 45.6
LED eteinte
20.8 45.6
LED allumee
20.8 45.6
LED eteinte
20.9 45.6
If I don't add the await in the read handler, it doesn't work and I get an error as soon as the app tries to connect (see below)
        ___  __          __
20.8 46.6
20.9 45.9
20.8 45.8
20.8 45.7
20.9 45.8
  File "main.py", line 91, in read_temp
I've noticed two things: (1) the button_handler doesn't have to be async for this to work - why I don't know (yet) and (2) the error seems to be coming from the read_handler, which can't read the sensor data, which is also not synced to the app in this case as well. I'm wondering if reading the sensor in a single async function into global vars and then making these available to the read_handler alleviates this. Making run() async seems to have been a step in the right direction though.
There is also the uPyBlynk lib (https://github.com/lemariva/uPyBlynk) which seems a little more straightforward and works in test. It also doesn't rely on declaring handlers with '@' - maybe this is a little more amenable to being re-written with async. I really want to make the official blynk lib work though because it seems it allows more customization and is the 'official' supported lib.
Primesty
Post by Primesty » Fri Mar 19, 2021 2:07 am
So, I think I figured it out!!!!
First, I re-wrote the run() function in blynk-lib to include async functionality.
                    self.connect()
                        raise
                        self.log(b_err)
                        self.disconnect()
                        self.log(g_exc)
            except:
                pass
10 ms seems to work fine. I haven't had any failures because of that. Then I pulled apart that initial long @blynk.handle_event('read V4') statement and broke it up into two individual ones as well as having a designated async read_temp function that reads the sensor data into two empty lists.
temp = []
hum = []
    if hum[0] > 60:
        blynk.set_property(H_VPIN, 'color', '#FF0000')
        blynk.virtual_write(H_VPIN, hum[0])
        print(READ_PRINT_MSG.format(vpin))
@blynk.handle_event('read V3')
def read_handler_2(vpin):
    if temp[0] > 22:
        blynk.set_property(T_VPIN, 'color', '#FF0000')
        blynk.virtual_write(T_VPIN, temp[0])
This now works beautifully! No failures so far. The code now runs the sensor measurement and the blynk run function asynchronously. Everything is pretty much updated in real-time and even the conditional color parameters work flawlessly and show up in the blynk app reliably. Interestingly enough, the handler functions don't need async capabilities. I assume this is now handled through the async run() function.
The next step is to package my testing setup into an blynklib_mp.mpy version, which includes the new async run function to save memory and space.
Here is the final main.py code
#import blynklib_mp as blynklib
import blynk_test as blynklib
import dht
import uasyncio
import gc
import random
WIFI_SSID = 'XXX'
WIFI_PASS = 'XXX'
wifi.active(True)
# initialize Blynk
blynk = blynklib.Blynk(token = "XXX", server = 'X.X.X.X', port = XXXX)
T_COLOR = '#f5b041'
H_COLOR = '#85c1e9'
T_VPIN = 3
H_VPIN = 4
temp = []
hum = []
READ_PRINT_MSG = "[READ_VIRTUAL_PIN_EVENT] Pin: V{}"
        sensor.measure()
        temp.clear()
        temp.append(temperature)
        hum.clear()
        hum.append(humidity)
        print(temperature, humidity)
        await uasyncio.sleep_ms(500)
    if hum[0] > 60:
    if temp[0] > 22:
        if value == ['1']:
                print('LED on')
                led(1)
                print('LED off')
                led(0)
        import sys
        sys.exit()
async def main():
    await blynk.run()
finally:
    uasyncio.new_event_loop()  # Clear retained state
