How does file transfer to target device work?
How does code and other files get transferred to the PyBoard, or other target? It's not a problem, just curious. It's working fine with Thonny. I can see a ttyACM0 device over which the REPL is accessed, just curious how this is used to transfer files. Was thinking I might automate some things down the line.
Re: How does file transfer to target device work?
Have been browsing and I think I'll find the answer by playing with rshell.
I've also written a script https://github.com/dhylands/upy-example ... e_files.py that takes some files and generates a files.py file. You can then run that on the board using pyboard.py
I think using rshell is easier (disclaimer I wrote rshell).
Thank you for this... and for rshell
