Hi there !
in this days i start to work width ST7735R display 128*160 16 bit color , i wrote my own libray and work . The problem is the SPI too slow for color the entire screen i need the wait two seconds. I think the problem is the SPI (be onest i don't connect the logic analyzer). Some one have my same problem ? there are other library or some trick or i need the write my own spi libray ?
Thank you
Sergio
ESP32 SPI
Re: ESP32 SPI
SPI itself is sufficiently fast. for your device you have to send ~300k bits for a full screen. At 10MHz SPI that takes about 30 ms. Micropython is slow. I do not know how you have set up your code, but if you write single pixels than you have a lot of overhead. It get's faster if you write larger pieces of the screen at once.
Re: ESP32 SPI
Is true i write single bit, but i don't have any idea how write large piece of the screen, please can you give me some idea ?
