status of IP connectivity GSM/mobile modems (i.e. sim800L)
Posted: Thu Apr 15, 2021 4:42 pm
by jcolo
I have been checking out the forums and the web at large.
It is not yet clear to me what is the state of the IP stack for connecting devices to a public wireless network, generally via the serial ports.
I understand from the downloads page that PPP is part of the v1.14 firmware. I cannot find anywhere how to use it.
Can somebody give me some insights ?
I would like to connect a couple of esp32 based modules via wireless using a couple of SIM800L I have.
I could use others if that is recommended.
Thanks.
JCG
Re: status of IP connectivity GSM/mobile modems (i.e. sim800L)
Posted: Tue Jun 08, 2021 8:35 pm
by katte82
I've recently developed a board with an esp32 and a simcom modem (i don't remember the exact code), with micropython and PPP.
I've connected the simcom with a uart present on the esp32.
This is my code.
I've not had any problem and all works like a charm.
import socket
#uart1 = UART(2, tx=17, rx=16, baudrate=115200, timeout=1000)
uart = UART(1, tx=2, rx=4, baudrate=115200, timeout=1000)
def receive():
x = uart.read()
if x is not None:
print('Received: {}\n'.format(x))
return x
def send(data):
print('Send: {}'.format(data))
uart.write(data)
time.sleep(0.3)
def demo():
pp = 0
pp_2 = 0
if pp == 0:
send('AT')
x = receive()
if x is not None:
if 'AT' in x:
pp += 1
pp_2 = 0
elif pp == 1:
cmds = ['ATE0', 'ATI\r\n', 'AT+CPIN?\r\n', 'AT+CREG=0\r\n', 'AT+CGREG=0\r\n']
send(cmds[pp_2])
x = receive()
if x is not None:
pp_2 += 1
if pp_2 == len(cmds):
pp += 1
pp_2 = 0
elif pp == 2:
send("AT+CREG?\r\n")
x = receive()
if x is not None:
if ('+CREG: 0,5' in x) or ('+CREG: 0,1' in x):
pp += 1
pp_2 = 0
elif pp == 3:
send("AT+CGREG?\r\n")
x = receive()
if x is not None:
if ('+CGREG: 0,5' in x) or ('+CGREG: 0,1' in x):
pp += 1
pp_2 = 0
elif pp == 4:
cmds = ['AT+COPS?\r\n', 'AT+CSQ\r\n',
#'AT+CNMI=0,0,0,0,0\r\n',
'AT+QICSGP=1,1,\"iot.1nce.net\",\"\",\"\",0\r\n', #'AT+CGDATA=?\r\n',
#'AT+CGDATA="PPP",1',
'ATD*99#\r\n'
send(cmds[pp_2])
x = receive()
if x is not None:
pp_2 += 1
pp += 1
pp_2 = 0
elif pp == 5:
print('Start PPP')
ppp = network.PPP(uart)
ppp.active(True)
ppp.connect()
i = 0
while i < 30:
time.sleep(1)
i += 1
if ppp.isconnected():
print(ppp.ifconfig())
pp += 1
break
elif pp == 6:
print('Try to send something.')
i = 0
exitwhile = False
while not exitwhile:
s = None
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.settimeout(3)
s.connect(('-----ip-----', 5555))
s.send('Hello world! ({})\n'.format(i))
i += 1
t = 5
data = ''
while t > 0:
time.sleep(1)
t -= 1
s.setblocking(0)
data = s.recv(1024)
except:
pass
if len(data) > 0:
exitwhile = True
t = -1
print('Received: {}\n'.format(data.decode('utf-8')))
break
except Exception as ex:
print(ex)
if s is not None:
s.close()
time.sleep(1)
pp += 1
elif pp == 7:
print('bye bye')
pp += 1
elif pp == 8:
pass
#time.sleep(1)
