I can see that the Current Time Service has the following:
name="Current Time Service"
type="org.bluetooth.service.current_time"
uuid="1805"
<Characteristics>
<Characteristic
name="Current Time"
type="org.bluetooth.characteristic.current_time">
<Requirement>Mandatory</Requirement>
name="Current Time"
uuid="2A2B">
<Value>
<Field name="Exact Time 256">
<Reference>org.bluetooth.characteristic.exact_time_256</Reference>
type="org.bluetooth.characteristic.exact_time_256"
uuid="2A0C">
<Value>
<Field name="Day Date Time">
<InformativeText>Reference the Time Characteristic</InformativeText>
<Reference>org.bluetooth.characteristic.day_date_time</Reference>
type="org.bluetooth.characteristic.day_date_time"
uuid="2A0A">
<Value>
<Field name="Date Time">
<Reference>org.bluetooth.characteristic.date_time</Reference>
name="Date Time"
type="org.bluetooth.characteristic.date_time"
uuid="2A08">
<Value>
<Field name="Year">
<InformativeText>Year as defined by the Gregorian calendar.</InformativeText>
<Format>uint16</Format>
<Unit>org.bluetooth.unit.time.year</Unit>
<Minimum>1582</Minimum>
<Maximum>9999</Maximum>
<AdditionalValues>
<Enumeration key="0" value="Year is not known" />
</AdditionalValues>
</Field>
<Field name="Month">
<InformativeText>Month of the year as defined by the Gregorian calendar.</InformativeText>
<Format>uint8</Format>
<Unit>org.bluetooth.unit.time.month</Unit>
<Minimum>0</Minimum>
<Maximum>12</Maximum>
<Enumerations>
<Enumeration key="0" value="Month is not known" />
<Enumeration key="1" value="January" />
<Enumeration key="2" value="February" />
<Enumeration key="3" value="March" />
<Enumeration key="4" value="April" />
<Enumeration key="5" value="May" />
<Enumeration key="6" value="June" />
<Enumeration key="7" value="July" />
<Enumeration key="8" value="August" />
<Enumeration key="9" value="September" />
<Enumeration key="10" value="October" />
<Enumeration key="11" value="November" />
<Enumeration key="12" value="December" />
</Enumerations>
</Field>
<Field name="Day">
<InformativeText>Day of the month as defined by the Gregorian calendar.</InformativeText>
<Unit>org.bluetooth.unit.time.day</Unit>
<Minimum>1</Minimum>
<Maximum>31</Maximum>
<AdditionalValues>
<Enumeration key="0" value="Day of Month is not known" />
</AdditionalValues>
</Field>
<Field name="Hours">
<InformativeText>Number of hours past midnight.</InformativeText>
<Unit>org.bluetooth.unit.time.hour</Unit>
<Maximum>23</Maximum>
</Field>
<Field name="Minutes">
<InformativeText>Number of minutes since the start of the hour.</InformativeText>
<Unit>org.bluetooth.unit.time.minute</Unit>
<Maximum>59</Maximum>
</Field>
<Field name="Seconds">
<InformativeText>Number of seconds since the start of the minute.</InformativeText>
<Unit>org.bluetooth.unit.time.second</Unit>
</Field>
</Value>
I have the following so far, but this only gets me as far as the Current Time Characteristic:
_CURRENT_TIME_UUID = bluetooth.UUID(0x1805)
_CURRENT_TIME_CHAR = (
bluetooth.UUID(0x2A2B),
bluetooth.FLAG_NOTIFY | bluetooth.FLAG_WRITE,
_CURRENT_TIME_SERVICE = (
_CURRENT_TIME_UUID,
(_CURRENT_TIME_CHAR,),
