About comments on main.py source code
photoacoustic
Post by photoacoustic » Wed Oct 21, 2015 10:50 am
Dear all,
I would like to know if there is some recommendation about comments in source file.
Can I put much as I like without losing memory?
Thanks in advance for your comments and suggestions
Best regargs
Damien
Site Admin
Re: About comments on main.py source code
Post by Damien » Wed Oct 21, 2015 11:14 am
Actual comments starting with a hash # are removed by the lexer and take no RAM. They only take space in the file itself. So you can write as many as you like.
Strings/doc-strings as comments do take some amount of RAM when compiling so better to avoid them.
photoacoustic
Post by photoacoustic » Wed Oct 21, 2015 12:52 pm
Thank for the response
kfricke
Post by kfricke » Wed Oct 21, 2015 3:46 pm
Interesting to know. Can you recommend some '#'-based comment style for the generation of documentation from code? I am thinking of some drivers which might need some love and could generate nice "Read the Docs" documentation. I hope that is reasonable!?
Damien
Site Admin
Re: RE: Re: About comments on main.py source code
Post by Damien » Wed Oct 21, 2015 4:12 pm
kfricke wrote: Can you recommend some '#'-based comment style for the generation of documentation from code?
I'd put restructured text in the comments. Easy to extract (just strip leading #) and then pass to sphinx.
