I needed to compile the MicroPython for NUCLEO_F767ZI with Ethernet supporting DHCP and with threads support.
I use the master version (commit 3ab8806c0d2fe77e9785216563b419cfadff71b0)
My first attempt was to use:
make BOARD=NUCLEO_F767ZI MICROPY_PY_LWIP=1 MICROPY_PY_THREAD=1 MICROPY_PY_THREAD_GIL=1
So I tried to add those parameters to the mpcofigboard.h
// Note: if the board shows odd behaviour check the option bits and make sure nD
// set to make the 2MByte space continuous instead of divided into two 1MByte se
#define MICROPY_PY_THREAD (1)
#define MICROPY_PY_THREAD_GIL (1)
#define MICROPY_PY_LWIP (1)
#define MICROPY_HW_BOARD_NAME "NUCLEO-F767ZI"
#define MICROPY_HW_MCU_NAME "STM32F767"
GEN build-NUCLEO_F767ZI/genhdr/qstr.i.last
In file included from ./mpconfigport.h:31,
from ../../py/mpconfig.h:62,
from ../../lib/oofatfs/ffconf.h:30,
from ../../lib/oofatfs/ff.h:33,
from ../../lib/oofatfs/ff.c:28:
boards/NUCLEO_F767ZI/mpconfigboard.h:6: error: "MICROPY_PY_LWIP" redefined [-Werror]
<command-line>: note: this is the location of the previous definition
from ../../py/asmthumb.c:31:
from ../../py/mpstate.h:31,
The above error is repeated many times.
So finally I had to build MicroPython for NUCLEO_F767ZI with:
Why MICROPY_PY_LWIP, MICROPY_PY_THREAD and MICROPY_PY_THREAD_GIL are treated in so inconsistent way?
TIA & Regards,
Wojtek
