I am attempting to use Firmware updat 1.14, after having been out of Micropython for a while. I am using a board that was previously used on firmware 1.9.3 and worked fine. however after creating a new board folder and using the PYBV11 files, with a few mods it compiles and runs, I am unable to access uart. When using UART(1,9600) "note also 1-4" it responds with
uart = UART('XB',9600)
ValueError: UART(1) doesn't exist
same response for
uart = UART(1,9600)
uart =UART(3,9600)
They were defined when the firmware was compiled as
// UART config
#define MICROPY_HW_UART1_NAME "XB"
#define MICROPY_HW_UART1_PORT (GPIOB)
#define MICROPY_HW_UART1_PINS (GPIO_PIN_6 | GPIO_PIN_7)
#define MICROPY_HW_UART2_PORT (GPIOD)
#define MICROPY_HW_UART2_PINS (GPIO_PIN_5 | GPIO_PIN_6)
#define MICROPY_HW_UART2_RTS (GPIO_PIN_4)
#define MICROPY_HW_UART2_CTS (GPIO_PIN_3)
#define MICROPY_HW_UART3_NAME "YB"
#define MICROPY_HW_UART3_PORT (GPIOB)
#define MICROPY_HW_UART3_PINS (GPIO_PIN_10 | GPIO_PIN_11)
I am wondering if newer firmware would have an issue with double defining in the
"mpconfigboard.h"
as in 1.9.3 i had them defined for I2c,SPI, and UART with no problem ... is this now an issue?
Compile new firmware, UART not available.
Re: Compile new firmware, UART not available.
UART, SPI and I2C are classes of the machine module. Did you call
upfront?
upfront?
