Noob: access to variable assigned Objects
nptech
Post by nptech » Sun Jun 20, 2021 5:28 am
say I:
motor_forward = machine.Pin...
motor_backward = machine.Pin....
& I wish to create 2 routines
def forward():
backward():
is it possible to initialise the pin's within the main body of code & gain access to them within my sub routines...?
or
is it possible to initialise the pins within there own routine e.g. def init():, run the init routine and still gain access to the pins via
other routines...
Re: Noob: access to variable assigned Objects
Post by Roberthh » Sun Jun 20, 2021 5:49 am
If you declare these pin objects as global in the functions, you can access them within the functions. For the declaration, just write:
global motor_forward, motor_backward
That's a Python property.
stijn
Post by stijn » Sun Jun 20, 2021 7:47 am
You can also pass things around as arguments:
def forward(motor):
  motor.high()
  motor.low()
def backward(motor):
  motor.low()
  motor.high()
def main()
  forward(motor_forward)
  backward(motor_backward)
which has the benefit it keeps on working when you add more motors
nptech
Post by nptech » Sun Jun 20, 2021 8:49 am
Thank you for the example reply :)
