AT+CSQ :bug with lte?
njepsen
Post by njepsen » Fri Jul 23, 2021 2:06 am
i am developing code for an online project (a data logger) using the esp32, and as part of testing i have run into an apparent issue with AT commands, and lte. If i repeatedly run AT commands using lte.send_at_cmd('AT+ ***') the script fails after a few minutes. i have written two test scripts - one using lte and one without.
1. WITH LTE
This is a simple script that attaches to NZ Spark provider and reads the CSQ every few seconds.
lte = LTE(debug = True)
lte.attach()
ctr=1
while not lte.isattached():
    print(ctr,' Attaching to Spark LTE network...')
    time.sleep(2.5)
    ctr = ctr +1
print("Modem ATTACHED to Spark LTE Network...")
ctr = 1
lte.connect()
while not lte.isconnected():
    print(ctr, 'Connecting to Spark LTE Network...')
    time.sleep(2.5)
    ctr = ctr + 1
print("CONNECTED !!!")
ctr = 0
lte.pppsuspend()
    print(lte.send_at_cmd('AT+CSQ'), 'iteration',ctr)
    sleep(1)
    ctr = ctr+1
This script runs for about 20 or 30 iterations then the response changes from +CSQ: 19,99 which is correct to +CSQ: 99,99 which indicates that the CSQ request is failing.
2. WITHOUT LTE
This script uses traditional AT commands to initialize uart1, define the cid and contextid, set the apn etc etc, attach and connect.
The main simply reads CSQ every 2 seconds. this script has been running now for 24 hrs without a hitch. The code is a bit clunky and I apologise for that but it has been hacked around a bit in testing.
 # test CSQ without lte
# Runs on Fipy
import gc
from time import sleep
from utime import sleep_ms, ticks_ms, ticks_diff
#  define Variables
m=0
#                        ATTACH
#   Attach to Network
def attach():
    success = 0
    for n in range(0,10):
      resp = send_to_uart('AT+CFUN?'+'\r')              # check Cfun
      success = search(resp,'OK')
      sleep(2)
      if success >0:
         break
      print('>> Attempting to attach')
      success=0
        resp = send_to_uart('AT+CGATT=1'+'\r')
        if success >0:
           print('>> ATTACHED')
           return success
           break
        sleep(10)
      if success<0:
         print('>> failed to attach')
    except Exception as e:
      print('## fail attempting to attach',e)
#                 send_to_uart
#  uart always responds to AT commands unless set to off
def send_to_uart(data):
      print('SND TO UART',data)
      uart.write(data)
     # print('>>data=',data)
      sleep_ms(50)
      r = read_uart()
   #   r= r.decode('utf-8').replace('\r','').replace('\n','').replace(' ','')
      print ('>> uart said',r)
      if r is None:
        r = b'\r\n ERROR \r\n'   #handling None is a PITA
      return r                # MUST be  byte object
      print('## -uart send failed with ',data,e)
# #                 Read Uart RESPONSE
def read_uart():
      uart_resp=uart.read()
      return uart_resp
      print('uart read failed',e)
#            Init uart1 which connected to the modem
def init_uart():
  print('INIT UART')
  global uart
    print('>> initialize uart1')
    uart = UART(1, baudrate=921600, pins=('P20', 'P18', 'P19', 'P17'),timeout_chars = 20000)
    print('>> init chars=',uart.any())
    return
    print('## cannot init uart',e)
#                    SEARCH
# search for substr inside  str
def search(str,substr):
   #return 0   ??
   # return 1  success
   #return -1  unsuccessful
   #       -2  nothing
   #       -3  error
   print('SEARCH')
         success=0
         err1 = "ERROR"
         err2 = "nothing"
         str = str.decode('utf-8')
         str = str.replace('\r','').replace('\n','').replace(' ','')
         print('>> seeking ',substr ,'in',str)
         if substr is  err1:
                success =-2
                print('no match')
         elif substr is err2:
              success = -3
              print('>> no match')
         if str.find(substr) is not -1:
           success = 1
           print('>> match found!')
           sleep(1)
           success = -1
           sleep(1)
         print()
         return success
       print('## "wait for", failed.',str,substr,e)
       sleep(10)
#               Modem Setup
# Note --MUST use cfun1,1
def modem_setup():
         list1 = ['AT+CFUN?','AT+CFUN=1,1','AT+CGDCONT= 1,"IP","internet.telecom.co.nz",,,,0,0,0,0,0,0',
                  'AT+CPMS="SM","SM","SM"','AT+CREG=1','AT+CMGF=1']
         success = 0
         for command in list1:
            for n in range(0,2):
             resp = send_to_uart(command+'\r')              #
             if success >0 :
               sleep(0.1)
               break   # jump to next 'command' from list  Break exits the inner loop only
    print('## new modem setup failed to run',e)
#                  RSSI
def rssi():
     print('>> RSSI')
     #must be called when attached but not connected
     csq=""
     n=0
     r=send_to_uart('AT+CSQ'+'\r')  #text mode
     success =0
           success = search(r,'OK')
           if success >0:
             csq = r.decode('utf-8')
             csq = csq.replace(" ","")
             csq = csq.replace('\r','')
             csq = csq.replace('\n','')
             print ('>> csq=',csq)
             rssi= (int((csq[5:7])) -2 )*2 -109
             print ('>> rssi=',rssi,'dBm')
             print()
             print()
       print('## calc RSSI function failed',e)
#                     Main loop
init_uart()
sleep(2)
modem_setup()
attach()
    m=m+1
    sleep(2)
    print('>> main loop >>',m)
    rssi()
Here is a sample of the second code shell
SEARCH
>> seeking OK in +CSQ:23,99OK
>> match found!
>> csq= +CSQ:23,99OK
>> rssi= -67 dBm
>> main loop >> 45
>> RSSI
SND TO UART AT+CSQ
>> uart said b'\r\n+CSQ: 22,99\r\n\r\nOK\r\n'
SEARCH
>> seeking OK in +CSQ:22,99OK
>> match found!
>> csq= +CSQ:22,99OK
>> rssi= -69 dBm
SEARCH
>> match found!
>> csq= +CSQ:22,99OK
>> rssi= -69 dBm
So my questions are:
1. Why does the lte version fail? I'm guessing it is an issue with lte, ( or more likly the way i'm using it) and not the Cat M1 service because the rssi is pretty respectable and the service doesnt fail after 24 hrs with method 2.
2. If either code stops for some reason a soft reset doesn't cut the mustard and a re-attach takes a LONG LONG time. If I do a power off the reconnect is almost instant.
williamhenrick
Re: AT+CSQ :bug with lte?
Post by williamhenrick » Sat Jul 24, 2021 8:36 am
Try restarting your board programmatically. When you encounter the error, restart your board via programming and then check, if its working fine. One possible solution: https://www.theengineeringprojects.com/ ... -nano.html
Last edited by williamhenrick on Fri Nov 05, 2021 6:34 am, edited 1 time in total.
njepsen
Post by njepsen » Sat Jul 24, 2021 10:23 pm
Thanks Bill. I have tried that but it is a last resort, and doesnt solve the issue with lte.
Since then I have re-written the entire script using AT commands rather than lte and it is running flawlessly, albeit a bit slower to connect & attach, but totally reliable.
