File "C:\Users\suppo\AppData\Local\Programs\Thonny\lib\tkinter\__init__.py", line 1705, in __call__
return self.func(*args)
File "C:\Users\suppo\AppData\Local\Programs\Thonny\lib\site-packages\thonny\workbench.py", line 1957, in toolbar_handler
handler(*args)
File "C:\Users\suppo\AppData\Local\Programs\Thonny\lib\site-packages\thonny\running.py", line 405, in cmd_run_current_script
self.execute_current("Run")
File "C:\Users\suppo\AppData\Local\Programs\Thonny\lib\site-packages\thonny\running.py", line 354, in execute_current
filename = get_saved_current_script_filename()
File "C:\Users\suppo\AppData\Local\Programs\Thonny\lib\site-packages\thonny\editors.py", line 1076, in get_saved_current_script_filename
filename = editor.save_file()
File "C:\Users\suppo\AppData\Local\Programs\Thonny\lib\site-packages\thonny\editors.py", line 273, in save_file
result = self.write_local_file(save_filename, content_bytes, save_copy)
File "C:\Users\suppo\AppData\Local\Programs\Thonny\lib\site-packages\thonny\editors.py", line 287, in write_local_file
f = open(save_filename, mode="wb")
FileNotFoundError: [Errno 2] No such file or directory: 'D:\\mainforSim800l.py'
below is the program we are trying to run
from machine import UART, Pin
import utime
from time import sleep
sensor_adc1_pir = machine.Pin(27, machine.Pin.IN, machine.Pin.PULL_DOWN)
sensor_adc2_pir2 = machine.Pin(28, machine.Pin.IN, machine.Pin.PULL_DOWN)
standdown_pir3 = machine.Pin(5, machine.Pin.IN, machine.Pin.PULL_UP)
sensor_dig1_pir4 = machine.Pin(14, machine.Pin.IN, machine.Pin.PULL_DOWN)
sensor_dig2_pir5 = machine.Pin(15, machine.Pin.IN, machine.Pin.PULL_DOWN)
bluelock_pir6 = machine.Pin(6, machine.Pin.IN, machine.Pin.PULL_DOWN)
outputrelay = machine.Pin(4, machine.Pin.OUT)
test_led = machine.Pin(8, machine.Pin.OUT)
activate = machine.Pin(7, machine.Pin.OUT)
def read_all(gsm):
c = b""
while gsm.any():
c += gsm.read(1)
sleep(0.0007)
print(c)
# Create the UART connection
gsm = UART(0, 9600, tx=Pin(0), rx=Pin(1))
sleep(0.5)
activate.on()
def pir_handler(pin):
if pin.value():
if pin is sensor_adc1_pir:
print("Alarm! sensor_adc1!")
test_led.value(1)
utime.sleep(0.2)
test_led.value(0)
elif pin is sensor_adc2_pir2:
print("Alarm! sensor_adc2!")
test_led.value(1)
utime.sleep(0.2)
test_led.value(0)
elif pin is sensor_dig1_pir4:
print("Alarm! sensor_dig1!")
test_led.value(1)
utime.sleep(0.2)
test_led.value(0)
elif pin is sensor_dig2_pir5:
print("Alarm! sensor_dig2!")
test_led.value(1)
utime.sleep(0.2)
test_led.value(0)
elif bluelock_pir6.value() == 0:
print("bluelock access!")
outputrelay.value(1)
gsm.write('AT\r\n')
sleep(1)
read_all(gsm)
gsm.write('AT+CSQ\r\n')
sleep(1)
read_all(gsm)
gsm.write('AT+CMGF=1\r\n')
sleep(1)
read_all(gsm)
gsm.write('AT+CMGS="+27733166980"\r\ndoor opened\r\n')
sleep(1)
read_all(gsm)
gsm.write('\x1A')
sleep(1)
read_all(gsm)
utime.sleep(20)
outputrelay.value(0)
utime.sleep(0)
sensor_adc2_pir2.value(0)
utime.sleep(10)
sensor_adc1_pir.value(0)
utime.sleep(10)
sensor_dig1_pir4.value(0)
utime.sleep(10)
sensor_dig2_pir5.value(0)
utime.sleep(10)
test_led.value(1)
utime.sleep(0.2)
test_led.value(0)
elif standdown_pir3.value() == 0:
print("door closed!")
test_led.value(1)
utime.sleep(10)
test_led.value(0)
sensor_adc1_pir.irq(trigger=machine.Pin.IRQ_RISING, handler=pir_handler)
sensor_adc2_pir2.irq(trigger=machine.Pin.IRQ_RISING, handler=pir_handler)
sensor_dig1_pir4.irq(trigger=machine.Pin.IRQ_RISING, handler=pir_handler)
sensor_dig2_pir5.irq(trigger=machine.Pin.IRQ_RISING, handler=pir_handler)
standdown_pir3.irq(trigger=machine.Pin.IRQ_RISING, handler=pir_handler)
bluelock_pir6.irq(trigger=machine.Pin.IRQ_RISING, handler=pir_handler)
