How to enable mDNS?
bulletmark
How to enable mDNS?
Post by bulletmark » Sat Aug 14, 2021 2:24 am
I understand MicroPython on ESP32 enables mDNS host announcement (since v1.12) but how can I get this to work? My ESP32 is connecting to my local network, e.g:
if not wlan.isconnected():
    wlan.active(True)
    wlan.connect('myssid', 'mypassword')
    while not wlan.isconnected():
        pass
I get an address and I can communicate fine on the network. How do I set this up to advertise a .local address so I can use this from a client machine instead of the IP address?
I can't find anything about mDNS in the MicroPython documentation and older threads here and elsewhere are vague.
bulletmark
Re: How to enable mDNS?
Post by bulletmark » Mon Aug 16, 2021 4:42 am
Well after reading around bug reports etc, and with some trial and error, I found the solution to my own question so will state it here given there is little documentation anywhere on how this works.
To be clear I want each esp32 running MicroPython on a DHCP network to create a unique hostname to which it will respond to regardless of the IP address it gets assigned (i.e. will respond a unique hostname to a mDNS query). I discovered that MicroPython (v1.16) does actually create a generic mDNS hostname called "Espressif" but that is useless when you have multiple esp32's on a network as I do. So I modified the above code to:
    wlan.active(True)
    mac = wlan.config('mac')
    host = 'esp32-' + ''.join('{:02x}'.format(b) for b in mac[3:])
    wlan.config(dhcp_hostname = host)
        pass
host = wlan.config('dhcp_hostname')
print('Wifi connected as {}/{}, net={}, gw={}, dns={}'.format(
    host, *wlan.ifconfig()))
Now you can ping/connect/etc to the device via it's reported unique name "esp32-xxxxxx.local" regardless of it's assigned IP address.
Post by pythoncoder » Mon Aug 16, 2021 6:58 am
That is neat and useful. You could alternatively use machine.unique_id().
bulletmark
Post by bulletmark » Mon Aug 16, 2021 7:32 am
machine.unique_id() returns exactly the same byte string as wlan.config('mac'). There is no point importing another package.
scruss
Post by scruss » Wed Jul 13, 2022 9:18 pm
On ESP32 it might, but not everywhere. For instance, on a Raspberry Pi Pico W:
mac: b'(\xcd\xc1\x00\x9d\xad'
unique_id: b'\xe6aLw[$15'
machine is usually imported by default, seemingly
bulletmark
Post by bulletmark » Wed Jul 13, 2022 10:44 pm
On a Raspberry Pi Pico W it might, but not everywhere. For instance, on a ESP32:
>>> machine.unique_id()
NameError: name 'machine' isn't defined
Post by jimmo » Thu Jul 14, 2022 12:43 am
On some ports there is frozen code that runs at startup to mount the filesystem etc which might import machine... Best not to rely on it.
