I am trying to freeze some code.
Board is a modified pyboard using a STM32F405
It works fine if I do not include __init.py__ in the manifest.
Here is my manifest file:
include("$(MPY_DIR)/extmod/uasyncio/manifest.py")
freeze("$(MPY_DIR)/drivers/dht", "dht.py")
freeze("$(MPY_DIR)/drivers/display", ("lcd160cr.py", "lcd160cr_test.py"))
freeze("$(MPY_DIR)/drivers/onewire", "onewire.py")
freeze("$(MPY_DIR)/CubScout_Frozen/modes",("__init.py__","normal.py","setup.py","test.py"))
#include("$(MPY_DIR)/CubScout_Frozen/modes/manifest.py")
Here's the output from the build using "freeze" function in the manifest:
brad@ubuntu:~/project/micropython/ports/stm32$ make BOARD=CUBSCOUT2
warn: unsupported file type, skipped freeze: __init.py__
I even tried with "__init.py__" containing only comments.
I followed the example for uasychio which also has an " __init.py__" file listed in the manifest and no problems.
I check the file permissions and they seem OK and consistent with the other modules in the release build.
brad@ubuntu:~/project/micropython/CubScout_Frozen/modes$ ls -al
total 48
drwxrwxr-x 2 brad brad 4096 Sep 6 20:21 .
drwxrwxr-x 3 brad brad 4096 Sep 6 20:15 ..
-rw-rw-r-- 1 brad brad 347 Sep 6 19:58 __init__.py
-rw-r--r-- 1 brad brad 277 Sep 6 20:21 manifest.py
-rw-rw-r-- 1 brad brad 12686 Sep 2 11:02 normal.py
-rw-rw-r-- 1 brad brad 4796 Aug 26 14:30 setup.py
-rw-rw-r-- 1 brad brad 8035 Aug 30 14:18 test.py
