Hi all, I am using raspberry pi pico with esp8266.My rp2 and esp8266 connection is like this
https://content.instructables.com/ORIG/ ... f467a3801a .My esp code is here
https://gist.github.com/Hermann-SW/e945 ... c679f48b03
and my raspberry pi pico code is
from machine import UART,Pin
uart = UART(0, rx=Pin(1), tx=Pin(0), baudrate=115200,rxbuf=512)
time.sleep(1)
uart.write("https://example.example.com"+"\n")
print(uart.read())
First i saw http response like 2 hours then i turn off power.When i power back on esp8266 is just sending none i mean i saw none on shell. Blue led is not blinking (when http response come blue led blink).I really don't know why is this happen this make no sense. Can anyone know what is the problem ? I tried Esp8266 with arduino , it is working without any problem (I used same metho uart 115200 ).What is the problem with raspberry pi pico. Thank you.
