deinit all timers?
bitrat
deinit all timers?
Post by bitrat » Thu Sep 23, 2021 9:34 pm
I was wondering if there is a way to deinit all timer callbacks in running code, without references to them.
Specifically, if I use ctrl-C to exit a program and drop into the REPL, timer callbacks are still executing. Should this happen, or is there a problem somewhere else in my code?
Cheers!
PS: I solved my earlier problem. I realised that my old code was catching all exceptions including ctrl-C and resetting. A case of more haste less speed... and not enough sleep...
Re: deinit all timers?
Post by Roberthh » Fri Sep 24, 2021 9:30 am
Soft-Reset stops all timers. It can be forced with Ctrl-D or calling machine.soft_reset().
