I try to get a cli interface over USB like the MP prompt >>> in my programm to enter in commands from CLI
the principe is simple call input() and wait for the command and execute it. so i can remote controll the device.
>here the command
but: all other threads slow down i guess, not 100% sure but a motor thread for a stepper slow down and the motor turn verry slow.
I use a ESP32 Lolin32 V1.0.0 with tmc2209 stepper driver
the code is shorted to make it more readable
hope someone can help.
# HW init ESP32
# LOLIN32 Wemos V1.0.0.
import micropython
import sys
import _thread
from time import sleep
from tmc.TMC_2209_StepperDriver import *
from statemachine import stepper_statemachine
debug = "position" # position, state, adc
# variables
movespeed = 500 #stepper move speed
parkposition= 600 #park position nach grinding ende
# Boot, following pins influence the serial bootloader mode
# https://github.com/espressif/esptool/wiki/ESP32-Boot-Mode-Selection
#12 (MTDI)
#15 (MTDO)
#GPIO0
#GPIO2
# HW init
led = Pin(5, Pin.OUT)
adc = ADC(Pin(36)) # create ADC object on ADC pin
endstop_i = 13
# HW inputs
endstop_in = machine.Pin(endstop_i, machine.Pin.IN, machine.Pin.PULL_UP)
# # Stepper
stepper = -1
tmc = TMC_2209(27, 14, 26)
tmc.setLoglevel(Loglevel.none)
tmc.setMovementAbsRel(MovementAbsRel.relative)
tmc.setDirection_reg(False)
tmc.setVSense(True)
tmc.setCurrent(200)
tmc.setIScaleAnalog(True)
tmc.setInterpolation(True)
tmc.setSpreadCycle(False)
tmc.setMicrosteppingResolution(2)
tmc.setInternalRSense(False)
tmc.setAcceleration(2000)
tmc.setMaxSpeed(movespeed)
# interrupt inputs
def callback(pin):
if (pin == start_in):
stepper.on_event('grind')
elif (pin == stop_in):
if not (str(stepper.state) == "MoveHomeState"):
tmc.stop()
stepper.on_event('move_home')
elif (pin == endstop_in):
tmc.stop()
pass
endstop_in.irq(trigger=machine.Pin.IRQ_FALLING, handler=callback)
kill_threads = False
# command cli
class PythonSwitch:
def cmd(self, command):
default = "Incorrect command, h for Help"
return getattr(self, 'case_' + str(command), lambda: print(default))()
def case_h(self):
return help()
def case_exit(self):
global kill_threads
kill_threads = True
my_cmd = PythonSwitch()
def help():
print("commands:")
print("h - help")
print("exit - exit programm to python")
def ledThread():
global kill_threads, stepper
if kill_threads:
print("exit ledThread")
_thread.exit()
led.value(not led.value())
sleep(1)
except OSError as e:
pass
def communicationThread():
global kill_threads
if kill_threads:
print("exit communicationThread")
_thread.exit()
var = input(">")
my_cmd.cmd(var)
sleep(0.2)
except:
pass
def adcThread():
global kill_threads, adc, adc_val, stepper
if kill_threads:
print("exit adcThread")
_thread.exit()
adc_val = adc.read() * 3.3 / 4095 # reading analog pin
print("adc:", adc_val)
sleep(0.1)
print("error ADC", e)
pass
def mainThread():
global kill_threads, event, tmc, stepper
state_tmp = -1
if kill_threads:
print("exit mainThread")
_thread.exit()
if not (state_tmp == str(stepper.state)):
state_tmp = str(stepper.state)
if(str(stepper.state) == "FinishState"):
finish()
elif(str(stepper.state) == "MoveHomeState"):
move_home()
elif(str(stepper.state) == "ErrorState"):
error()
sleep(0.2)
pass
def main():
if not stop_in.value():
print("kill_threads")
kill_threads = True
stepper = stepper_statemachine()
# start threads
_thread.start_new_thread(ledThread, ())
_thread.start_new_thread(adcThread, ())
_thread.start_new_thread(communicationThread, ())
_thread.start_new_thread(mainThread, ())
if kill_threads:
sleep(2)
stop()
print("poweroff")
sys.exit()
sleep(1.2)
if __name__=="main__":
main()
main()
