static IP on esp32 in AP mode?
bitrat
Post by bitrat » Mon Sep 27, 2021 6:14 am
I'm a bit dense when it comes to networking, so I'm not even sure if this make sense. Does the AP dynamically allocate it's own ip?
I've tried just using the ifconfig that's returned from ifconfig if I start wlan in AP mode with no config...
wlan.ifconfig( ('192.168.4.1', '255.255.255.0', '192.168.4.1', '0.0.0.0') )
I tried a few variations on the arguments as well, like...
wlan.ifconfig(config=('192.168.4.1', '255.255.255.0', '192.168.4.1', '0.0.0.0') )
..and..
wlan.ifconfig(0, ('192.168.4.1', '255.255.255.0', '192.168.4.1', '0.0.0.0') )
They all crash or return errors, eg:
TCP/IP Invalid Parameters
davef
Re: static IP on esp32 in AP mode?
Post by davef » Mon Sep 27, 2021 9:54 am
Did you:
ap_if = network.WLAN(network.AP_IF) #  create access-point interface
first?
Then maybe:
ap_if.ifconfig((config.WiFi_device, '255.255.255.0', config.gateway, '8.8.8.8'))
bitrat
Post by bitrat » Tue Sep 28, 2021 8:13 am
Thanks, yep, I did that. Think I need to do more research...
