json.loads(x) works, but json.load(frr) doesn't work. Data are the same.
Any idea?
>>> frr = open("jsdata.json", "r")
>>> x = frr.read()
>>> json.loads(x)
{'value_d1': [0, 1, 2, 3, 4, 5, 6, 7, 8], 'dtime': '00.00.00 00:00', 'value_d2': [0, 1, 2, 3, 4, 5, 6, 7,
8], 'device_2': 'Humidity', 'device_1': 'Temperature'}
>>> fr = json.load(frr)
ValueError: syntax error in JSON
json.load
Re: json.load
Hi Karebo Try with:
and with:
the problem is in the position of the cursor in the file.
If you use frr.read() the cursor is positioned at the end of the file and using json.load(frr) there is nothing else to read.
using the with you ensure a correct reading of the file and closing.
If you want to use the same FD then use the seek method.
with open("jsdata.json", "r") as frr:
x = frr.read()
json.loads(x)
json.load(frr)
Re: json.load
Thanks. My live will be better now
