I've made some progress on this, but interested in comments from uasyncio afficianadoes. Am I doing it right? Here's what the program does:
- Handle interrupts and post events to a shared event queue.
- Read a socket and post received messages to a shared event queue.
- Post 'ping' events to a shared event queue.
- Post adc events to a shared event queue.
- Consume the shared event queue and write events to the same socket in the main loop.
from machine import Pin, Timer, ADC
import uasyncio as asyncio
from ucollections import namedtuple
import micropython
import utime
import urandom
import usocket
import uerrno
def get_sock(ip, port):
sock = usocket.socket(usocket.AF_INET, usocket.SOCK_DGRAM)
sock.setsockopt(usocket.SOL_SOCKET, usocket.SO_REUSEADDR,1)
sock.settimeout(1)
sock.bind((ip, port))
return sock
class Board(object):
def __init__(self):
self.wlan_ = network.WLAN(network.AP_IF)
self.wlan_ .active(True) # must be true before using .config
self.wlan_.config(essid='ZZZ', password='ZZZ')
ifconf = self.wlan_.ifconfig()
print('ifconfig = {}'.format(ifconf))
self.ip_ = self.wlan_.ifconfig()[0]
self.port_ = 20001
def deactivate(self):
self.wlan_.active(False)
def host(self):
return self.ip_
def port(self):
return self.port_
Event = namedtuple("Event", ("events", "flag", "value"))
last_value_change_ms = 0
def debounce():
global last_value_change_ms
cur_time = utime.ticks_ms()
diff = cur_time - last_value_change_ms
bounce = diff < 500
last_value_change_ms = utime.ticks_ms()
return bounce
def add_button_event(event):
event.events.insert(0, 'B:{}'.format(event.value))
event.flag.set()
def get_button_handler(events, flag):
def handler(pin):
if debounce():
return
event = Event(events, flag, pin)
micropython.schedule(add_button_event, event)
return handler
board = Board()
sock = get_sock(board.host(), board.port())
sock.settimeout(0)
async def get_messages(events, flag):
global sock
BUFSZ = 1024
sock.settimeout(0)
await asyncio.sleep_ms(250)
message, address = sock.recvfrom(BUFSZ)
events.insert(0, message)
events.insert(0, address)
flag.set()
except OSError as e:
if e.args[0] not in [uerrno.EINPROGRESS, uerrno.ETIMEDOUT, uerrno.EAGAIN]:
raise
count = 0
async def ping(events, flag):
global count
await asyncio.sleep(10)
count += 1
message = 'PING:{}'.format(count)
flag.set()
pot = ADC(Pin(34))
pot.atten(ADC.ATTN_11DB)
pot_prev = 0
pot_curr = 0
def add_adc_event(event):
global pot
global pot_prev
global pot_curr
pot_curr = pot.read()//100
if abs(pot_curr - pot_prev) > 1:
pot_prev = pot_curr
event.events.insert(0, 'POT:{}'.format(pot_curr))
event.flag.set()
def get_adc_handler(events, flag):
def handler(timer):
event = Event(events, flag, timer.value())
micropython.schedule(add_adc_event, event)
return handler
def add_ping_event(event):
global count
event.events.insert(0, 'ZZZZ:{}'.format(count))
event.flag.set()
def get_ping_handler(events, flag):
def handler(timer):
micropython.schedule(add_ping_event, event)
return handler
async def reactor():
global sock
pins = [14, 15, 27]
events = []
flag = asyncio.ThreadSafeFlag()
for p in pins:
pin = Pin(p, Pin.IN, Pin.PULL_UP)
pin.irq(trigger = Pin.IRQ_FALLING, handler = get_button_handler(events, flag))
await asyncio.sleep(0)
timer0 = Timer(0)
timer0.init(mode=Timer.PERIODIC, period=500, callback=get_adc_handler(events, flag))
timer1 = Timer(1)
timer1.init(mode=Timer.PERIODIC, period=5000, callback=get_ping_handler(events, flag))
asyncio.create_task(get_messages(events, flag))
asyncio.create_task(ping(events, flag))
address = None
if len(events) == 0:
await flag.wait()
while len(events):
event = events.pop()
print(event)
if type(event) == tuple:
address = event
elif address is not None:
sock.sendto(event, address)
asyncio.run(reactor())
