Hey, guys!
I was wondering if mounting the Linux filesystem through MicroPython is even possible and, if it somehow is, how could I go about that? The reason why I am trying to accomplish this is because I would like to be able to read files from the host's filesystem.
Thanks in advance!
Reading files from Linux filesystem
Re: Reading files from Linux filesystem
So you want to mount a linux filesystem from an attached Micropython board, like a Pyboard?
Or do you want to access files running the Linux port of MicroPython.
One answer: Using mpremote on your host, you can indeed mount a directory of the Linux host at the micro, making it appear as local directory of the micro. But that works only as long as you are using mpremote for the communication.
