Q.on use of ujson
ebolisa
Q.on use of ujson
Post by ebolisa » Mon Nov 29, 2021 10:53 pm
The following code fails on an ESP because the data file contains a string. However, it runs on my win box.
Why is that?
TIA
#alarm = [1, 2, 3, '4']
import ujson
data_file = 'data.json'
alarm = []
# with open(data_file, 'w') as f:
#     ujson.dump(alarm, f)
with open(data_file, 'r') as f:
    alarm = ujson.load(f)
>>> %Run -c $EDITOR_CONTENT
File "<stdin>", line 11, in <module>
ValueError: syntax error in JSON
curt
Re: Q.on use of ujson
Post by curt » Mon Nov 29, 2021 11:29 pm
Are you sure the read is actually reading the entire file?
stijn
Post by stijn » Tue Nov 30, 2021 7:13 am
Just a guess but have you tried with 'rb' instead of 'r'? Also: hard to tell without seeing the exact file contents.
ebolisa
Re: Q on use of ujson
Post by ebolisa » Tue Nov 30, 2021 7:31 am
Sorry for the late reply. It was bed time for me right after I posted the question.
The json syntax error drove me nuts till I found out it was the text datatype in the array the the culprit.
However, it's working this morning, so I can only guess the ESP needed to be cooled down :|
