Hello
What are my options to know, is location exists, is it a file or directory ?
Location is directory or file
Re: Location is directory or file
See https://docs.micropython.org/en/latest/library/os.html and
viewtopic.php?t=5291
It's really fascinating what a Google search (in this case: "Micropython directory") might return.
A few hours of debugging might save you from minutes of reading the documentation!
import os
for loc in os.ilistdir('.'):
if loc[1] == 0x4000: # folder
print(loc[0]+'/')
else: # file
print(loc[0]+':', loc[3], 'bytes')
1602clock.py: 385 bytes
cardkb.py: 725 bytes
dir.py: 181 bytes
id.py: 102 bytes
lib/
rnd_spd2.py: 295 bytes
rnd_spd3.py: 273 bytes
tm1638tst.py: 215 bytes
touch.py: 136 bytes
Google? never heard of it
This is what i came up with:
Thanks for pointing me to 0x4000 direction
def file_exists(path):
f = open(path, "r")
f.close()
return True
except OSError:
return False
def dir_exists(path):
if os.stat(path)[0] & 0x4000:
return True
return False
except OSError:
return False
