Getting RGB values out of image
Hey there! Is there any option on getting RGB values out of an image? I could not find anything. Is this possible in pure python?
Re: Getting RGB values out of image
You'll have to give us more information if we are to help. Please describe the image format.
It’s 8x8 PNG. I need to get the RGB value of every pixel in the image.
PNG format is quite involved. For a file that small it might be worth using a format conversion tool to copy it to a simpler format such as uncompressed BMP. Getting pixel data from that should be fairly easy.
Thank you! I will look into this tomorrow.
Any tips on how to convert this? I can only find solutions that involve using Pillow :/pythoncoder wrote: ↑Sun Dec 05, 2021 6:47 pmPNG format is quite involved. For a file that small it might be worth using a format conversion tool to copy it to a simpler format such as uncompressed BMP. Getting pixel data from that should be fairly easy.
As usual there are two options. Search for a library someone's already written; failing that, look up the spec for a BMP file and do it yourself.
This isn't something I've investigated in detail, but I do know that uncompressed BMP is one of the simplest graphics formats.
