Using MPy 1.17, stm32F405
I have a program that will do some os tasks on the flash memory such as renaming and moving files and directories. After this, it issues:
os.sync()
pyb.hard_reset()
In some rare cases, it won't reboot as the file system became corrupted.
So is it possible that os.sync() is still in running when the hard reset occurs?
In other wordsk, is os.sync() a non-blocking task?
is os.sync a non-blocking?
Re: is os.sync a non-blocking?
Almost all corruption issues are due to this problem.
So a possible solution is to insert some delay (more than 10ms) after os.sync()?
If the problem is as per my FAQ quoted above, the only solution is to disable MSC mode. The files can be accessed from your PC using tools such as mpremote and rshell.
Thanks. Now it makes sense.
The FAQ link was difficult to see on my browser.
