I am trying to set up a docker environment for running a micropython script, but am running into a strange issue,
I have built micropython and can enter the interactive repl and so i know micropython is working.
The issue I am facing is around importing modules, if I run a file using "micropython/ports/unix/micropython-dev imports.py" I get the following output:
DL imagetools uasyncio/stream upip_utarfile
__main__ lodepng ubinascii urandom
_thread lv_timer ubluetooth ure
_uasyncio lv_utils ucollections uselect
btree lvgl ucryptolib usocket
builtins math uctypes ussl
cmath micropython uerrno ustruct
display_driver termios uhashlib usys
display_driver_utils uarray uheapq utime
evdev uasyncio/__init__ uio utimeq
fb uasyncio/core ujson uwebsocket
ffi uasyncio/event umachine uzlib
fs_driver uasyncio/funcs uos
gc uasyncio/lock upip
Plus any modules on the filesystem
None
File "imports.py", line 4, in <module>
ImportError: no module named 'upip'
print(help('modules'))
import upip
Has anyone else come accross something similar before?
