Github token authentication with OTA
ncotti
Post by ncotti » Thu Dec 23, 2021 8:05 pm
HI!
After doing some testing, I'm facing a strange behaviour with Github authentication system through OTA.
I'm basically doing this request to the Github API:
get('https://api.github.com/repos/path', headers={'Authorization': 'token my_token'} )
And written like this, it successfully authorizes the connection, allowing me to bypass the request from 60 to 5000 as seen here: https://docs.github.com/en/rest/overvie ... e-limiting
However, when I try to connect multiples pyboards at the same time, some of them end up connecting unauthorized and running out of request, leading up to not being able to finish the update.
I would like to know if anyone knows why this could be happening and if there is some way to reliable connect to the Github Api as an authorized user.
dotoyas12
Re: Github token authentication with OTA
Post by dotoyas12 » Tue Mar 15, 2022 4:23 am
HI!
However, when I try to connect multiples pyboards at the same time, some of them end up connecting unauthorized and running out of request, leading up to not being able to finish the update.Best Wusthof Knife 2022
Also wanted to know this. We should wait for the experts. If you already got the answer then can you share with us? Thanks in advance
