Calculate percent value
Filip
Re: Calculate percent value
Post by Filip » Wed Jan 19, 2022 2:24 pm
davef wrote:
Wed Jan 05, 2022 6:52 pm
Maybe I should have said "decimal" places. Especially with 1-wire measurements and using round 1 on the returned floating point number, I would often get:
66.4
66.30001
66.2
FYI: I learned this today:
if 66.3 == round(66.30001, 1):
    print("Rounding is fine")
print("This should not print 66.30001 on Pico but it does:", 66.3)
scruss
Post by scruss » Wed Jan 19, 2022 4:26 pm
round() returns a float, and 66.3 is one of those numbers that doesn't have an exact representation in single-precision float.
If you think about it, in 32 bits, there are of the order of 2^32 (roughly 4.3 * 10^9) distinct values you can store. And yet, we somehow manage to jam the number range of roughly +/- 10^38 into those 32 bits. So there must be some (quite a lot, actually) of numbers we can't represent as a float.
So best to use format, f-strings or the '%' operator rather than round. And please, don't feed that rounded value back into your program unless you want to discover chaos theory all over again.
(NB: old notation alert, for i am old: "^" means "to the power of" here. I don't know how the cool kids type it today. I thought it might be more readable than "4.3E09", which is more my jam)
KJM
Post by KJM » Wed Jan 19, 2022 11:09 pm
I've been dodging the round problem by sticking to integers. With battery voltage for example that means working in mV then diving by 1000 at the end when it's time to print or otherwise output a result. The other advantage of sticking with integers is you can do an integer division (//) anytime intermediate results get cluttered with a stupid number of decimal places & not worry too much about accuracy loss.
Post by pythoncoder » Fri Jan 21, 2022 10:04 am
If you think about it, in 32 bits, there are of the order of 2^32 (roughly 4.3 * 10^9) distinct values you can store. And yet, we somehow manage to jam the number range of roughly +/- 10^38 into those 32 bits. So there must be some (quite a lot, actually) of numbers we can't represent as a float...
Given the infinity (aleph one) of reals between 0 and 1 that is very true :lol:
