Is there a micropython library that supports 7seg displays ? (With LCD_SEGx pins)
Liquid crystal display controller (LCD)
The LCD drives up to 8 common terminals and 44 segment terminals to drive up to 320
pixels.
• Internal step-up converter to guarantee functionality and contrast control irrespective of
VDD. This converter can be deactivated, in which case the VLCD pin is used to provide
the voltage to the LCD
• Supports static, 1/2, 1/3, 1/4 and 1/8 duty
• Supports static, 1/2, 1/3 and 1/4 bias
• Phase inversion to reduce power consumption and EMI
• Integrated voltage output buffers for higher LCD driving capability
• Up to 8 pixels can be programmed to blink
• Unneeded segments and common pins can be used as general I/O pins
• LCD RAM can be updated at any time owing to a double-buffer
• The LCD controller can operate in Stop mode
