Deepsleep wake only on rising pin?
BetterAutomations
Post by BetterAutomations » Mon Jan 17, 2022 11:07 pm
I have two pins on an ESP32 that are often held high. How do I have them only wake the device when it's rising and not already held? The device won't stay in deep sleep when it's held high.
It's a door sensor. When the door is open I send an alert then deep sleep until the close sensor is detected.
Relevant code:
    door_open_pin = machine.Pin(DOOR_OPEN_PIN, machine.Pin.IN, machine.Pin.PULL_DOWN)
    door_close_pin = machine.Pin(DOOR_CLOSE_PIN, machine.Pin.IN, machine.Pin.PULL_DOWN)
    esp32.wake_on_ext1(
        pins=(door_open_pin, door_close_pin),
        level=esp32.WAKEUP_ANY_HIGH)
BetterAutomations
Re: Deepsleep wake only on rising pin?
Post by BetterAutomations » Tue Jan 25, 2022 7:00 pm
Worked around my problem using a combination of AND, OR, and NOT gates with capacitors to create a rising pulse detector circuit, only for waking the device. Once woken it reads the state of the pins. Uses one extra GPIO for the wake, but I can have as many pins waking it as I need by branching into more OR gates.
Falstad:
https://www.falstad.com/circuit/circuit ... CpBgIPhYgA
