reading PIR sensor/pin via interrupt
fluxmonkey
Post by fluxmonkey » Wed Jan 19, 2022 4:20 am
TW: TOTAL NOOB question. I'm working through "Getting Started with Micropython on Raspberry Pi Pico", there's a Burglar Alarm project using the HC-SR501 PIR sensor. The example code works:
import utime
sensor_pir = machine.Pin(28, machine.Pin.IN, machine.Pin.PULL_DOWN)
def pir_handler(pin):
    utime.sleep_ms(100)
    if pin.value():
        print("Danger Will Robinson!!!")
sensor_pir.irq(trigger=machine.Pin.IRQ_RISING, handler=pir_handler)
and prints out the message whenever the PIR is triggered. What I want to do is print one message on trigger, and then another when the PIR untriggers (pin28 returns to low). I tried this:
    utime.sleep_ms(100)
    if pin.value()==1:
    elif pin.value()==0:
        print("coast is clear")
and multiple other permutations of if and elif; I still get the Danger message but never the clear. I may not understand, in the textbook example, what exactly that if is evaluating... is that "if pin.value is not empty", or?
I also tried adding second .irq with an IRQ_FALLING condition, but by then I was just randomly flailing and not getting anywhere. Thanks in advance for your help!
iiLaw
Re: reading PIR sensor/pin via interrupt
Post by iiLaw » Sun Jan 23, 2022 9:07 pm
Hi have you played with utime.sleep_ms(100) which looks to me as denounce so you could lengthen it as PIR can be very noisy in terms of triggering. Is the PIR on a module as some have back off timer of 5 sec to stop re-triggering.
The other thing is to put a pin read in a loop and print state as that might help showing what's going on.
You will need something like time.ticks_us() I'm new to micropython so can't say how to use but a google should help
I found this thread
viewtopic.php?t=4641#p26839
