Are file writes non blocking?
KJM
Post by KJM » Wed Jan 19, 2022 11:01 am
I've got a problem with
with open('update', 'w') as f: f.write(update); print('update stored'); machine.deepsleep(900*1000)
Where update is a 29k text file. The problem is the update file is created in flash but has nothing in it. I don't understand how the print can output if the write hasn't happened?
I tried allowing some extra time for the write to occur with
with open('update', 'w') as f: f.write(update); time.sleep(1); print('update stored'); machine.deepsleep(900*1000)
but same result, the appearance of a zero size update file in os.listdir() after the program has run.
If I move the write a few lines further up before the deeplseep it works properly but I don't understand why. Can anyone suggest what's going on?
scruss
Re: Are file writes non blocking?
Post by scruss » Wed Jan 19, 2022 4:28 pm
write needs a flush or the passage of time to make them happen
Post by Roberthh » Wed Jan 19, 2022 5:05 pm
Try to write the code a little bit different.
    f.write(update);
As far as In understand, everything behind the : after with or if or ... is considered as a single statement. And since that includes deepsleep(), the automatic flush() after the with statement does not happen.
davef
Post by davef » Wed Jan 19, 2022 6:25 pm
Even a print() statement before lightsleep() or deepsleep() needs a wait or you only get part of it.
    print ('going to lightsleep() for the timer duration')
    utime.sleep(.5) #  so print() works
    machine.lightsleep(5 * 1000)
KJM
Post by KJM » Wed Jan 19, 2022 10:35 pm
Looks like I'm a victim of my penchant for multi cmd lines! If I limit myself to 1 cmd per line I end up doing a LOT of scrolling due code dev. Is there a way around this or do I need to get a bigger monitor & set it up in portrait mode?
Post by dhylands » Wed Jan 19, 2022 11:29 pm
How are you checking the file size?
I don't think that closing the file means that it's written to the filesystem by the time that the close returns.
I think you would need to call os.sync() to ensure that everything has actually been committed to flash. deepsleep is like a reset, so if the data was sitting in memory in a cache, it's gone by the time deepsleep returns since deepsleep is like a reset.
KJM
Post by KJM » Fri Jan 21, 2022 12:26 am
I gave that a try in an attempt to force a flush
os.sync()
but I must be doing it wrong?
line 101 AttributeError: module object has no attribute sync
Post by Roberthh » Fri Jan 21, 2022 10:11 am
you can use f.flush(), or simply leave the with() code block after with. That will close the file, and on file close the buffer will be flushed as well. So if you write your code in proper style, everything should go well.
	f.write(update)
You problem is, that the deepsleep() call is on the same code line as the with(). Then, the with code block was not left before deepsleep, and the intrinsic flush and close did not happen.
Edit: The ';' in a statement list binds stronger than the colon ':'. So the statement list after 'with' is treated as a single statement.
