Micropython UART doesn't work on Picos RP2040
rjw
Re: Micropython UART doesn't work on Picos RP2040
Post by rjw » Wed Jan 19, 2022 5:28 pm
I tried it with the rshell, the same problem.
MicroPython v1.18-5-g037b2c72a-dirty on 2022-01-19; Raspberry Pi Pico with RP2040
>>> import testUART2.py
No response at all.
Post by Roberthh » Wed Jan 19, 2022 5:31 pm
So you did the wiring, and the patch wires ate fine?
Post by Roberthh » Wed Jan 19, 2022 5:33 pm
Since you use an own build: did you try a firmware from the download page?
rjw
Post by rjw » Wed Jan 19, 2022 5:34 pm
I don't understand what you mean.
Post by Roberthh » Wed Jan 19, 2022 5:48 pm
How do you connect UART 1 tx with uart 0 rx
rjw
Post by rjw » Wed Jan 19, 2022 5:54 pm
with a nearly 10 cm long breadboard cable,
and I checked it with an Ohm meter
