UART write int array
abreyu
Post by abreyu » Thu Jan 27, 2022 10:21 am
hi
what is the best way to write an int array to uart? I've never used python, maybe my conversion from int[] to string is wrong:
array = [42, 86, 127]
buf = ''
for i in array:
    buf += chr(i)
uart.write(buf)
[edit]
ok, i solved it like this:
byte_array = bytearray(array)
uart.write(byte_array)
now I'm working on read data:
sleep_ms(100)
rxData = bytes()
while uart.any() > 0:
    rxData += uart.read(1)
print(rxData)
whithout sleep_ms(n) I cant read data, no better way to achive the result?
Online
Re: UART write int array
Post by Roberthh » Thu Jan 27, 2022 1:13 pm
Obviously your code has to wait for response. Instead of waiting for a fixed time, you can poll UART using uart.any(), like:
while uart.any() == 0:
    time.sleep_ms(1)
If you count the loop iterations, you can implement a timeout.
