mpy-cross
Posted: Fri Jan 28, 2022 5:01 am
by KJM
I finally got a version of mpy-cross running in Windows 10
C:\Users\Admin>pip install mpy-cross
Collecting mpy-cross
Downloading mpy_cross-1.18-py2.py3-none-win_amd64.whl (158 kB)
|████████████████████████████████| 158 kB 6.8 MB/s
Installing collected packages: mpy-cross
Successfully installed mpy-cross-1.18
unfortunately the upython on my esp32 is version 1.17.
1) Does anybody know what pip install cmd would get me the 1.17 version of mpy-cross?
2) Can someone give me a link that explains how to use mpy-cross to produce a .mpy file
Re: mpy-cross
Posted: Fri Jan 28, 2022 7:15 am
by mattyt
Take a look at
mpy-cross v1.17 on PyPi.
You'll also find basic documentation on how to use it on that page. Basic use:
Re: mpy-cross
Posted: Fri Jan 28, 2022 11:12 pm
by KJM
That don't work for me Matt
C:\Users\Admin>mpy-cross test.py
OSError: 2
If I get into the options at the bottom of that page I get
C:\Users\Admin>python -m mpy_cross -v -X main.py
usage: C:\Users\Admin\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.9_qbz5n2kfra8p0\LocalCache\local-packages\Python39\site-packages\mpy_cross\mpy-cross.exe [<opts>] [-X <implopt>] <input filename>
Options:
--version : show version information
-o : output file for compiled bytecode (defaults to input with .mpy extension)
-s : source filename to embed in the compiled bytecode (defaults to input file)
-v : verbose (trace various operations); can be multiple
-O[N] : apply bytecode optimizations of level N
Target specific options:
-msmall-int-bits=number : set the maximum bits used to encode a small-int
-mno-unicode : don't support unicode in compiled strings
-march=<arch> : set architecture for native emitter; x86, x64, armv6, armv7m, armv7em, armv7emsp, armv7emdp, xtensa, xtensawin
Implementation specific options:
emit={bytecode,native,viper} -- set the default code emitter
heapsize=<n> -- set the heap size for the GC (default 2097152)
I feel like it's trying to tell me something but I'm not sure what it is.
Also, any tips on how to install on a Rpi? Maybe it would run there if I could just figure out how to install it?
root@raspberrypi:/home/pi# pip install mpy-cross==1.17
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting mpy-cross==1.17
Could not find a version that satisfies the requirement mpy-cross==1.17 (from versions: )
No matching distribution found for mpy-cross==1.17
root@raspberrypi:/home/pi# pip3 install mpy-cross==1.17
Re: mpy-cross
Posted: Sat Jan 29, 2022 7:11 am
by KJM
OK I finally got mpy-cross 1.17 to work from the windows cmd line. I fed it a 29k .py file & it spat out a 10k .mpy file. My problem now is it doesn't seem to work. I've tried loading it onto the esp32 as main.mpy or main.py, neither seems to run at power up. I've tried importing it in the repl but it doesn't run after I do.
This is proving much harder than I expected. Any thoughts on why the .mpy is only half the size of the original .py & what I might do to find out what's wrong with it?
Re: mpy-cross
Posted: Sat Jan 29, 2022 3:37 pm
by scruss
50% size reduction sounds about right. But what are you expecting mpy-cross to do?
It's mostly used for reducing the file size and memory footprint of micropython modules. I haven't seen it used to compile main.py, but lots of libraries in /lib benefit from being run through mpy-cross
