Storing global configuration settings
p_j
Post by p_j » Fri Feb 25, 2022 5:59 am
Any thoughts on what is the most efficient way to store global config data that can be accessed from all modules?
I have been using a settings.py file with GLOBAL but after watching one of Damien's pycon talks on optimisation I'm concerned my method is horribly inefficient!
This is what I am doing at the moment
settings.py
import os
import sys
from machine import UART, Pin, WDT, Timer, SoftI2C, SoftSPI, RTC
from utils import AESTtime
import DS3231
import logging
def init():
    global DATE_STRING, EX_RTC, RTC, INA3221, WLAN_SSID, WLAN_PASS, HOSTNAME, BROADCAST_ADDRESS, BROADCAST_PORT, UART, I2C
    RTC = RTC()
    INA3221 = None
    WLAN_SSID = "GIGI-BEAR"
    WLAN_PASS = "xxx"
    BROADCAST_ADDRESS = "192.168.17.255"
    BROADCAST_PORT = 3000
    UART = UART(1, baudrate=115200, tx=37 , rx=38, txbuf=4096, rxbuf=4096, timeout=0)
    I2C = None
    current_date = AESTtime(time.time())
    DATE_STRING = f'{current_date[0]}-{current_date[1]:02d}-{current_date[2]:02d}'
    # Setup I2C
        I2C = SoftI2C(sda=Pin(33), scl=Pin(34), freq=400000)
        LOGGER.debug("I2C started")
    except:
        LOGGER.debug("Couldnt start I2C")
        EX_RTC = DS3231.DS3231(I2C)
        EX_RTC.get_time(set_rtc=True)
    except:
        print("Couldnt connect to DS3231")
boot.py
import settings
settings.init()
other files
import settings
settings.UART.write("Hello World!\n)
scruss
Re: Storing global configuration settings
Post by scruss » Wed Jul 13, 2022 8:55 pm
Such a complex set of shared settings only makes sense if you're deploying lots of the same board. As soon as you start including different hardware, access methods like serial and I2C go out the window.
I rather like - even if it stomps on a standard Python library name - Adafruit's "secrets.py" from CircuitPython. It's a very simple hash table:
# This file is where you keep secret settings, passwords, and tokens!
# If you put them in the code you risk committing that info or sharing it
secrets = {
    'ssid' : 'your-ssid-here',
    'password' : 'your-password-here',
If you import this, secrets.secrets["ssid"] will access the shared value
Post by jimmo » Thu Jul 14, 2022 12:40 am
This is a fine way to do it.
The optimisation issue is that accessing settings.UART.write is expensive because each layer is a dictionary lookup. (globals -> settings -> UART -> write). If this is an issue in a tight loop you can do:
   uart_write = settings.UART.write
   for ...:
     uart_write(...)
p_j
Post by p_j » Mon Jul 18, 2022 10:03 am
   for ...:
     uart_write(...)
Thanks I'll keep that in mind, I do have some places where the lookups are a few levels deep.
p_j
Post by p_j » Mon Jul 18, 2022 10:12 am
secrets = {
I like the simplicity of this but yes I'm planning to deploy a large amount of boards with the same hardware.
danhalbert
Post by danhalbert » Thu Aug 25, 2022 7:06 pm
CircuitPython recently added `.env` (dotenv) support: https://docs.circuitpython.org/en/lates ... index.html, which we use to setup credentials for the new web workflow. It is meant to be accessible outside the VM if necessary.
