Good morning. I have developed my own board using the STM32F746G microchip and the mt25ql256aba1ew9-0sit QSPI flash. I created my own external loader which I used to upload the filesystem to the QSPI flash. I have also developed my own .elf file to run on the board. The .elf file works perfectly fine when I run the filesystem on the internal flash. However when I edited the .elf file to allow for executing the filesystem in the QSPI, I get the error "MPY: can't mount flash". I can access micropython through the repl but cannot run the filesystem that I have stored on the QSPI. The filesystem is stored at location 0x90000000 in the quad spi and the main micropython program runs on the internal flash starting at location 0x08000000. I am not sure if the filesystem has to be stored in a different location in the QSPI or if I am missing some commands in the setup in the .elf file.
I only want to read the filesystem from the QSPI and execute it. Any help on the matter will be gladly appreciated.
Storing file system in external QSPI in read only format.
