Urequest HTTP Post ECONNRESET
reyhg_
Post by reyhg_ » Wed Mar 23, 2022 1:52 pm
I am trying to upload data from sensor to sql with my ESP32 via http post. I create localhost with XAMPP and want to try to upload data using urequest library but get error massage ECONNRESET. Here my code.
import urequests as requests
import json
url="http://127.0.0.1/esp_send.php/"
send={"s1":"11187","s2":"65","s3":"54","s4":"1"}
head={'Content-Type': 'application/x-www-form-urlencoded'}
r=requests.post(url=url, data=json.dumps(send), headers=head)
results = r.json()
print(results)
After i run it, i get this error massage
  File "<stdin>", line 6, in <module>
  File "urequests.py", line 120, in post
  File "urequests.py", line 60, in request
OSError: [Errno 104] ECONNRESET
In python i tried using this code and found no problem.
import requests
data={"s1":"11","s2":"12","s3":"13","s4":"14"}
resp = requests.post(url, params=data)
Please any help is highly appreciated. Thanks in advance.
Edit
I change the ip to IPv4 Address and turn of firewall but another problem occur. In mysql it just send empty string and i dont know what wrong.
ebolisa
Re: Urequest HTTP Post ECONNRESET
Post by ebolisa » Mon Apr 04, 2022 5:14 pm
You should post the php code.
Anyway, try this:
# sending post request and saving response as response object
URL="http://127.0.0.1/esp_send.php/"
DATA={"s1":"11187","s2":"65","s3":"54","s4":"1"}
r = requests.post(url = URL, data = DATA)
# extracting response text
url_response = r.text
print("The response from URL is:%s"%url_response) # prints a feedbac from the php file
karfas
Post by karfas » Mon Apr 04, 2022 6:27 pm
I think you should add the address of the server where your PHP script is running.
Your code might be great to try it out on the server, but 127.0.0.1 is always localhost (the machine where the script runs).
Maybe a little reading about TCP basics might help ?
