Hi community,
How can I use the WiFi for the PyBoard SF2. The documentation seems outdated for this board which is a big bummer for me: https://docs.micropython.org/en/latest/ ... ckref.html, or am I just looking at the wrong place here? Could anyone provide me an example code?
I tried the network code for the ESP32, but as I thought (logically) it does not work for the PyBoard.
Any help is welcome
How to use the WiFi on the PyBoard
Re: How to use the WiFi on the PyBoard
I found an old forum post when the Pyboard first came out that referenced this site:https://pybd.io/hw/pybd_sfxw.html#wifi-control and that seems to be the same as the WLAN documentation: https://docs.micropython.org/en/latest/ ... .WLAN.html
Thank you! Now I can connect to a network, awesome.dhylands wrote: ↑Sun Apr 10, 2022 3:51 amI found an old forum post when the Pyboard first came out that referenced this site:https://pybd.io/hw/pybd_sfxw.html#wifi-control and that seems to be the same as the WLAN documentation: https://docs.micropython.org/en/latest/ ... .WLAN.html
Now the next part.. how can I make (GET, POST) requests? The 'urequest' module doesn't seem to work on the PyBoard. Next to requests I would also like to try websockets. Do you have any idea on how to do this for the PyBoard?
I'm actually trying to do exactly the same thing.
You can find urequests.py here: https://github.com/micropython/micropyt ... equests.py
So checkout the micropython-lib repository: https://github.com/micropython/micropython-lib/
and set an environment variable MPY_LIB_DIR to point to the micropython-lib directory.
Then go into the micropython/ports/stm32/boards/PYBD_SF2 and edit manifest.py and add this line to the end:
and if you rebuild micropython, it will have urequests.py builtin as a frozen module.
Alternatively, you could just copy urequests.py onto your pyboard.
freeze("$(MPY_LIB_DIR)/python-ecosys/urequests", "urequests.py")
I got picoweb running on my pyboard D and I put all of the files together over here: https://github.com/dhylands/picoweb
